Where is the joint connector for the fogs
Old Nov 28, 2010 | 11:36 AM
jgilbs's Avatar
Hey guys,
I have an '03 SE, and recently, I have been trying to troubleshoot my fogs. They worked when I got the car in August, but they, the orange side marker lights, and the clear light above the turn signals in front no longer work. Yesterday I had my car jacked up to change the oil pan, and decided to tackle the fogs as well while I was waiting for the RTV to dry.
I checked the relay box, and I DO have 5v on terminal 5 when the lights are on. According to the FSM, from the relay box, the Black/Orange wire goes to a "joint connector", then to each individual lens. For the life of me, I cannot find this connector to check it. Does anyone know where it is located? (yes, I HAVE searched)
Old Nov 28, 2010 | 04:45 PM
CMax03's Avatar
Was this car modded to have to foglights illuminate off the parking lights? If so you'll be searching for the joint splice connectors. Maybe you should check the bulbs just incase the output side of the lights were tapped into....if the bulb false so does the circuit being feed from it too!
Old Nov 28, 2010 | 08:30 PM
jgilbs's Avatar
No signs of foglight modification from the previous owner. The connector for the foglights does NOT have +12v on it. Since the joint connector is the only thing that should be in between the relay and this connector, this is why I am looking for the joint connector
But that is a good point, I will check the bulbs next chance I get
Old Nov 28, 2010 | 11:34 PM
CMax03's Avatar
The foglight harness plug is behind the wheelwell splash shields.....if thats what you're looking for.....
Old Dec 1, 2010 | 09:47 PM
jgilbs's Avatar
I found that plug. I am looking for the connector where the single wire from e relay splits off into 2 wIres for the 2 different sides (driver and passenger fogs)
Old Dec 1, 2010 | 11:35 PM
CMax03's Avatar
use a tone generator and amplifier to find it!
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
