My Car is now a turd!!!!!!!!!!!
So i finally got around to gutting my cats and now my car is a turd.
Why is this.Also i now have a leak at the rear pre cat and can't figure out where its coming from. All of you running those non fouler's which o2 did you install them on and what was the part number? I saw 2 or 3 different ones at auto zone.
You need two anti-foulers.
The primary O2 sensors do not need anti-foulers, otherwise you'll run rich as hell.
Only the secondaries need them to keep the secondary sensors from reading a rich condition.
Are you talking sluggish throughout the entire RPM range? Or just down low, like in every-day part throttle driving?
I could see a small decrease in down low throttle response due to the reduction in backpressure, but the increased flow up top should more than make up for it.
I'll be doing this soon, too, so I'm curious as to your outcome, and as to codes as well.
Ok went to auto zone to get the antifoulers, and to check the codes had 4 of them. P0420 and P0430 Efficiency below threshold Bank 1 and Bank 2. Two antifoulers came in a pack, do i use both in a pack on 1 sensor or one on each?
Yes, you put it on the secondary sensors. That is great picture. Is it from the factory service manual?
However, putting them there will only fix the P0420 and P0430 code. Your car will continue to run bad unless you find the real cause.
- Viikas
- Viikas
You're part way there taking the pre-cats off! Just sayin...
The car is running better now, but i can't really drive it like i wanna. Dam tranny started slipping more than it was all of a sudden.I didn't get headers because i don't have a job but i'll purchase after i do my tranny swap.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
altome15
Aug 10, 2015 07:05 PM
[/IMG]
) and weld some straight pipe through them. If that is done, there should take out any questions regarding turbulence.
