How to remove rear bumper ?
Old 12-03-2010, 12:41 AM
Saadkhan07's Avatar
Guys,
I tried searching, i couldnt find a tutorial...but...i got into a small bump...and need to pop the dent out of my rear bumper. its in the left corner, right where the bumper lines up with the tail lights. Any idea on how hard/easy ? i have been told that both rear lights have to be removed, and some misc clips. Any possible way to pop dent out without removal ?
appreciate anything !
Thanks !
Saadkhan07 is offline
Old 12-03-2010, 04:52 AM
xdsub40's Avatar
Originally Posted by Saadkhan07
Guys,
Thanks !
I can tell you exactly how to do it cuz i just put my bumper back on after having it repainted yesterday
Yes you do have to remove both tail lights because there are 2 clips under each tail light that hold the bumper in place. It is fairly simple but just takes time. Here's how...
First take out the screws and clips under the bumper. There should be about 4 screws and 2 clips total. Then go into your trunk and start removing the tail lights (there should only be 4 nuts on each light then just pry it out slowly with a screw driver. Remove the 2 clips under each tail light as mentioned earlier then you're almost done. There are two screws inside of you rear fenders (mine were gold screws and do the left one first cuz the screws are easily visible and you'll know what you're looking for cuz the right ones are hidden). Last but not least, there is one nut each on the inside corners of your trunk. Then you're done.
All you'll need is a flat head screw driver, a 10mm deep socket w/ extension, and an 8mm deep socket. It took me about 30 min to take it off cuz i had to figure it all out but only 20 to install it back on and EVERYONE knows that its harder to intall than to remove.
xdsub40 is offline
Old 12-03-2010, 05:38 AM
Tippy Toes's Avatar
Takes about 20-30 minutes if you have some help - read above - its fairly simple - toughest thing I had was remembering the rear light sockets and which ones went where - just take some tape and mark them real quick - I would suggest having someone do it with you so the bumper isnt flexing awkwardly upon mounting it - good luck
Tippy Toes is offline
Old 12-03-2010, 07:36 AM
xdsub40's Avatar
+1 I took it off alone but putting it back on alone would have been a mission!
xdsub40 is offline
Old 12-03-2010, 10:20 PM
Saadkhan07's Avatar
Guys,
Thank you tons !!!!! xdsub, your steps were on point ! thank you tons ! Thanks for your info tippy, i appreciate it. got it off and on with ease,alone !
I was disappointed on how THIN this bumper is ! my 93 accord's bumper was solid and did not bend no where near this one ! but, i got the dent out and its back on.
APPRECIATE IT !!
Old 12-04-2010, 05:51 AM
xdsub40's Avatar
Congrats!!
xdsub40 is offline
Matt93SE
05-24-2019 02:58 PM
Dennis Twohy
10-01-2015 06:01 PM
JoshG
21
09-04-2015 09:04 PM
umnitza
09-01-2015 01:03 PM
steven4838
08-26-2015 11:04 AM
Quick Reply: How to remove rear bumper ?
