Cold start problem
Old Dec 27, 2010 | 04:40 PM
atomztwins's Avatar
Cold start problem
On cold mornings when I first start the car, it stutters and stumbles and then dies after only a few seconds. When starting it the second time, it runs fine. Now, as it has gotten even colder, or if the car sits for more than a couple of days, the problem is even worse. It will die the first time, then one the second time it will run for about a minute, then die. It seems to miss a bit while it is warming up, but seems to run fine after it has ran Ifor a few minuites. Any ideas? Intake gasket? It is cali spec and throwing a 430 code. could it be a vaccum leak?
Old Dec 27, 2010 | 04:47 PM
Clean your TB/IACV.
Old Dec 27, 2010 | 05:55 PM
atomztwins's Avatar
Thanks!
Old Dec 27, 2010 | 05:56 PM
VQ'rInWLA's Avatar
Clean your TB/IACV.
Old Jan 4, 2011 | 02:37 PM
atomztwins's Avatar
Ok, I pulled the TB/IACV and cleaned the crap out of them with gumout carb cleaner. They were pretty dirty, however, the problem did not completely go away. This morning was about 10 deg. The car did its usual stumble and die on the first try and then ran the second time. Before, it would have died after about 30 sec. on the second run. It does seem to run better, though. Anything else I need to check?
Old Jan 4, 2011 | 08:06 PM
LETINES's Avatar
Good chance you have a small leak in the plastic intake manifold. In the cold weather they warp just enough to have the car run like crap. I lived with it for awhile but had a friend change the intake gasket and never had a problem. Car ran perfect in the warm weather
Old Jan 4, 2011 | 09:11 PM
JonBlz's Avatar
a.k.a. STuNtMAN
the code you have
P0430 - Catalyst System Efficiency Below Threshold (Bank 2)
Old Jan 6, 2011 | 03:42 AM
atomztwins's Avatar
I thought that code meant the front precat, but with the coold starting issue, could an intake leak be throwing that code as well? I unplugged the battery for 30 min. yesterday, an this morning it started up and ran perfectly the first time. The CE light did come back on almost immediately, though. It usually takes quite a few run cycles to come on after I reset it. Thanks for all the help guys.
Old Jan 6, 2011 | 01:49 PM
atomztwins's Avatar
This morning the car started and ran great, but today, when it was completely warmed up, I noticed that now it is idling at about 1200 RPM. Am I missing something here? Throttle Position Sensor?
Old Jan 8, 2011 | 05:28 AM
atomztwins's Avatar
OK, I'm stupid (in case you guys haven't figured that out yet), but I tried the throttle position sensor relearn twice and had no luck. It still idles at 1200. What is the CONSULT II and where can I get one? Ebay? I checked there, but just want to make sure I get the right thing.
Old Jan 10, 2011 | 07:16 AM
ColdRain's Avatar
which car is this??? 5th gen or 5.5 ? if its 5th gen there is an idle screw near throttle cables which you can lower to 750, once car is completely warmed.
Old Jan 15, 2011 | 05:36 AM
atomztwins's Avatar
Its a 5th gen. Thanks for the info. Last tank of gas I got 14.5 avg cold weather all city driving. I am beginning to think it has to be an intake leak with such horrible mileage.
Old Jan 17, 2011 | 07:13 AM
ColdRain's Avatar
Please, let us know how it turns out. I may be in same boat and we are sinking in fuel tank.
Old Jan 17, 2011 | 10:23 AM
Prophecy99's Avatar
i have a 5.5 and have had extremely simalur issues at start up, and now that i think of it similar mpg sypmtoms, and a whistling which is suspect to a leak
Old Sep 24, 2011 | 05:58 PM
jetsfanez's Avatar
tough.
Old Sep 30, 2011 | 10:21 PM
Bjdjncaw22@gmail.com's Avatar
I Have the same prob on my 2000 maxima.
What does TB/IACV stand for?(I know I'm stupid)
Old Oct 3, 2011 | 12:44 PM
joemax2000's Avatar
I had this problem for a while. Had a hole in the rubber intake tube after the MAF and before the intake manifold, replaced it and it runs perfect. Had the same issues, word for word, with the guy in the first post.
Old Oct 5, 2011 | 04:32 PM
tetete's Avatar
I am having the same issue right now.
Cold start around 10c in the morning.
Stop with idle at the red light 100m away from my apartment,
The car shakes like crazy, and I have to chose P, and step on gas to make at least 1200rpm to stop the shake.
I will take a look in to the TB/IACV and the rubber intake and report back
Old Nov 20, 2011 | 01:12 AM
tetete's Avatar
some one still reading this?
Old Nov 20, 2011 | 09:44 AM
getflushed's Avatar
ive had some issue with mine not starting... i saw some guys post about an issue he had.... he said he unpluged his lower tps plug (the one that senses closed and open throttle.... to activate evap).... well i unplugged mine and has started on a dime everytime .. i still have it unplugged!! his thread is mcmelkins should be not too far down the list here as i.posted on it on friday at like 5... its even stopped my rough idle.. im buying.a.new tps tomorrow!
Old Nov 20, 2011 | 12:26 PM
blkdrgn613's Avatar
im going to guess that its Throttle Body / Intake Air Control Valve
im trying to find a walkthrough on dissemble and cleaning for the 5.5 gen, but cant find one yet.
tsi6001
Oct 3, 2022 10:23 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
FlaMark
Aug 21, 2015 11:06 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
