Any Help? Cylinder wall Markings
Old Dec 28, 2010 | 04:12 PM
02SE6MT's Avatar
I just picked up a longblock from a maxima and when i got it on a stand and spun the crank to inspect it i saw some markings in one of the cylinder bores. It doesnt feel rough or as though there is any unusual wear. Does any one have an idea what this could be a result of? Is it potentially hazardous to the reliability of the engine?
Here are some pics:
Old Dec 28, 2010 | 05:48 PM
P. Samson's Avatar
That looks like corrosion.
Old Dec 28, 2010 | 06:01 PM
CMax03's Avatar
Looks like where some moisture was trapped between the piston and cylinder...No big worry if your fingernails don't feel it....
Old Dec 28, 2010 | 06:05 PM
02SE6MT's Avatar
thats what i was initially thinking, (or oil blow by-but i dont know if that would even leave marks). im just surprised at the lack of any surface damage or roughness. it's as smooth over the marking as the rest of the bore.
Old Dec 28, 2010 | 06:09 PM
02SE6MT's Avatar
Well that's good news, i cant tell any difference in the coating on the bore or any roughness whatsoever. ty for the reply
Old Dec 28, 2010 | 06:19 PM
P. Samson's Avatar
That dark "tinting" is the indication of minor/early corrosion in steel/cast iron. You probably won't feel it......it doesn't appear to have even caused any minor pitting yet.
Old Dec 28, 2010 | 06:31 PM
02SE6MT's Avatar
Samson That dark "tinting" is the indication of minor/early corrosion in steel/cast iron. You probably won't feel it......it doesn't appear to have even caused any minor pitting yet.
so just how bad is it? will it continue to worsen? if i were to put it back together is engine failure bc of the corrosion inevitable?
sorry for all the questions
Old Dec 28, 2010 | 06:46 PM
P. Samson's Avatar
It won't cause a "failure" and it appears to be so minor that it shouldn't cause any issues. A few "wipes" of the piston rings on the next startup should remove it, is my guess.
Old Dec 28, 2010 | 10:30 PM
CMax03's Avatar
Engine was setting for awhile it was wasn't running if it got those marks...no biggie, scotch brite will remove, it but it'll be gone with a few rotations of the crank, possible be hand....
Old Dec 29, 2010 | 10:21 AM
02SE6MT's Avatar
ty for all of the prompt replies, i really appreciate it. I have been stressin since i saw it.
Old Dec 29, 2010 | 11:13 AM
KRRZ350's Avatar
Yeah I wouldn't stress that at all either, otherwise looks great.
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
