Help, Problem Starting
Old Dec 29, 2010 | 12:37 PM
GoPack's Avatar
Starting this week every once in awhile when i go to start my car i will turn the key and only get a "clicking" sound. After turning the key 4 or 5 times it will finally turn over and start up. Once it did take about 10 times turning the key before it started. I put a brand new battery last winter. Also replaced +battery cable end. Any ideas i'm worried its gonna strand me somewhere. Thanks.
Old Dec 29, 2010 | 12:39 PM
ColdRain's Avatar
could be starter/grounding, any lights?
Old Dec 29, 2010 | 12:42 PM
Stormzusmc's Avatar
check all connections (lugs and wires)
test ur battery - go to auto store and have them do a load test
then test ur starter - take starter off have them test it
Old Dec 29, 2010 | 12:43 PM
ColdRain's Avatar
rather go to advance auto vs. autozone. autozone starter test only does pass/fail, doesnt help much when starter works but not at full cycle.
Old Dec 29, 2010 | 12:49 PM
GoPack's Avatar
yea i have lights.
006r's Avatar
I would check connections as stated then worry about starter...although it is quite possible it could be a starter issue.
Old Dec 29, 2010 | 12:54 PM
GoPack's Avatar
best solution take starter off and take to advance auto to be tested? is there a solenoid on the starter?
Old Dec 29, 2010 | 12:55 PM
Stormzusmc's Avatar
i said auto store, not zone
and im not sure about where to take the starters, if i need it tested i have a local place that does it for me not an auto parts store that sells 300 dollar chrome strips
putting a battery load tester on the battery and cranking it up to the rated cca will tell you if the battery is good or not by checking to see if the voltage holds..i have a battery load tester at home so i dont have to worry about it
you can also check each cell for specific gravity if it is not a sealed battery so see which cell is bad, but you have to have a refractometer
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
