Car died and does not start, HELP!!!
Old Dec 30, 2010 | 09:06 AM
FriscoMaxima's Avatar
Hello,
I have a 2000 Maxima GXE Auto. Came out of the house yesterday to repark the car. Started it up and the car ran for about 20-30 seconds and then died. I was not able to start it since. The engine cranks and it feels like ignition is ok but it just does not want to start running again.
*Battery is at 12.6V
*All ignition coils are with "grey dot"
*MAF was replaced with an updated one.
*Fuel pump fuse is OK
Never had starting issues prior to this...
Thank you.
Old Dec 30, 2010 | 09:11 AM
foodmanry's Avatar
Da Roller Coaster!
Sounds like it is not getting fuel. Check the fuse for the fuel pump.
Old Dec 30, 2010 | 09:18 AM
Stormzusmc's Avatar
yeah most likely a fuel issue in this case
Old Dec 30, 2010 | 09:55 AM
The fuel pump fuse looks ok. Where is the fuel pump relay located on these cars... I have trouble finding it... :-(
Old Dec 30, 2010 | 10:02 AM
foodmanry's Avatar
Da Roller Coaster!
Hmmm...good question. I could not find is the FSM. Perhaps it is located near the fuel pump assembly in the tank. I'm not sure thought, hopefully someone else has some insight.
Old Dec 30, 2010 | 10:13 AM
TheIntrepidMontti's Avatar
I had this happen on my 99 maxima and it turned out my chip in my key broke, went to the dealer got a new key programed and i was on my way... so it could be the same issue
Old Dec 30, 2010 | 12:23 PM
I tried two keys... No success.. :-(
Old Dec 30, 2010 | 12:29 PM
I tried 2 keys as well to no avail... it was like they had to reset the immobilizer or something for it to work. but it sounds like the same problem as mine started then died after ~20 sec. or so... the battery looked good and you could hear it trying to crank but it just wasent getting fuel, i had it sitting in a local shop for days with them scratching their heads before i took it to a dealership.
Old Dec 30, 2010 | 01:08 PM
Feldman's Avatar
Should be able to hear if the pump is running just by turning the key but not starting and listening for the wine of the pump.
Where do you live? If its freezing outside and your tank is running low you could have some ice in your fuel lines. Just a though
your security light will stay lit while you are trying to start the car if there is an immobilizer issue.
Old Dec 30, 2010 | 01:37 PM
DennisMik's Avatar
The fuel pump relay is in the driver side footwell, behind the kick panel on the left side. The fuel pump relay and the rear defogger relay are mounted on a bracket that is tucked away in there.
Old Dec 30, 2010 | 04:58 PM
foodmanry's Avatar
Da Roller Coaster!
Good to know...
Old Dec 30, 2010 | 05:12 PM
I am from San Francisco, California. No sub-zero temperatures here...
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
