Tachometer needle not going down smoothly
Old Jan 1, 2011 | 07:46 PM
mahanddeem's Avatar
Hi
just wanted to ask about my tachometer needle,when I rev let's say 2k or 3k RPMs , the needle goes up normally but goes down in steps , not very prominent thought but kinda not smooth as when going up !
is it something with the tacho it self ? or related to MAF or TB ?
thanks
Old Jan 2, 2011 | 01:33 PM
shdwonthsun's Avatar
stock gauge faces/cluster?
if so, cluster probably going bad. if not, you broke the steppers swapping
Old Jan 2, 2011 | 02:44 PM
datsunzcar84's Avatar
Mine does the same thing . It's kinda funky it goes up and down though the range seeming almost like it is sticking for a split second .. Is this a common problem for the 5.5 gen?
Old Jan 2, 2011 | 03:28 PM
jonnypax09's Avatar
could just be rubbing against the faceplate, thats what solved my problem. sometimes that faceplate moves around and if you do happen to take it apart you'll see how it all goes together.
this link by shift ice will pretty much tell you how to remove the cluster IF you plan on taking it apart yourself
http://www.shiftice.com/chrome_rings.html
Old Jan 2, 2011 | 05:38 PM
Not sure about the Op but, I have a stocker gauge cluster.
MR2 T'd
Jul 9, 2021 05:06 AM
Mar 12, 2020 12:06 AM
TKHanson
Nov 24, 2018 01:39 AM
captchaos
Mar 15, 2016 12:18 PM
jchronis2552
Sep 21, 2015 05:52 AM
