BC Racing Coilovers Discussion
i think they suggest the 5mm preload once youre installing the coilovers regardless...at least thats whats ive been reading so far...regardless of how they are coming from the factory im still going to do this...i ordered my set this week and should receive them by the weekend so i guess ill see if they are as good as everyone says they are
the more preload you set, the lower the car will go also the harsher the ride is...set it to 0 and you'll be fine
essential just installed his...if they are not as shown in that thread, just swap the coilover...right to the left and vice versa. obviously no need to take off the camber plate. just make sure that the holes/slots are parallel w/ the headlights
So what happens if it doesn't have the right camber plate positions? Did yours? I know a few people on the org have installed BC coilovers recently and seemed happy with them... I just ordered them today from jmautoracing, so I hope they'll have the right camber plates, etc...
lol when you buy the supposedly best struts (illuminas) and you have to use zipties all of a sudden you just dont care lol. when i put on my coilovers i pulled out the zipties, my mechanic/stepfather said, 'you dont need those, wheres teh brake line clip' lolol. too use to using zipties
Hi guys,
Just wanted to address the camber plate positions that a few individuals have experienced.
I've installed about 10 sets of brand new BC coilovers over the past 5-6 months. EVERY ONE of them had 'incorrect camber plates.' The L/R sticker underneath was placed on the wrong side.
What I've actually been doing is swapping the LOWER mounting bracket, not the camber plate. Just unscrew them all the way down the threads and swap.
It's just as effective as camber plate, and it makes no difference if you decide to swap the bracket or the camber plate, simply an alternative for you to know about.
This issue does seem to be widespread and I am glad that BC is doing something about it.
Funny thing is...same thing is happening on the 7-8 Megan's I've installed too....
Id like to add that my passenger front coil is stuck completely from adjustment. Ive tried everything except torching it. I had a mechanic try to loosen it and he couldnt. Do you guys know what the rebuild entails? Can I send it in for repair?
I'd suggest everyone greases and puts anti-seize on theres. I've had mines on for over 1 1/2 years. So combined with the person before me, its about 2 years of use.
really glad this thread exists. I'm in the same situation as the OP and am interested to get his feedback. If the BCs really are as adjustable as people are making them out to be(Upstate NY Winters), they definitely have me over the Teins. It'd be pretty risky to attempt driving around in 6+ inches of snow when the highest the Teins'll go are 1.5in(f) and .8(r) lower than stock. How are the BCs are as far as max height is concerned?
I used a mixture of PB and Mobil 1 synthetic grease, threaded up and down without a problem.
i use a wire brush to knock off all the dirt in the threads before i start to do ANYTHING, then i always use white lithium grease to lube mine up...unlock them..move the collars all teh way up and all the way down, then reset them at the height i want..maybe more work to get my height, i just hope this will mean in teh future i wont have to worry about them locking up
You're local. PM me if you have any questions.
Initial Impressions/Pics
Alright, so I got my BC Racing coilovers installed last night and I wanted to share my first impressions and some initial pictures.
Install wasn't bad at all. The part that takes by far the longest is trying to get all 4 wheels to sit at the right height (when you adjust one, it messes up other ones). Anyway, as of now, the car is sitting pretty close to 25" ground to fender on all 4 wheels (with all my tools/jacks in the back). I'll probably try to fine tune it a bit over the next few days, but for now it's not bad.
Handling... Well, it's amazing! Coming from an almost 10-year-old stock suspension, there was obviously a huge difference. I have the dampening set to 14 front, 15 rear (from soft), and so far that's my favorite setting. To use the common expression, it handles like it's on rails.
One thing that surprised me is that even with an all around 25" height, I haven't bottomed out at all yet. The coilovers keep each wheel nice and stiff, and even going through deep intersection dips, I haven't had any problems. I was a bit worried about being this low, but it seems to be working out just fine.
Here are some initial pics... Pardon my dirty car, it's been raining and muddy here for the last 5 days.
So I've been driving on my BC Racing coilovers for 4 days now and I noticed an unexpected and very positive effect... they make my car feel a lot quicker! I wonder if that's just because of less power loss due to decreased suspension movement during acceleration? Whatever the reason, I love it.
Anyway, I got my ride height fine-tuned where I like it. The ground to fender measurements are just under 25 on the front and just over 25 on the rear. I tried just over 24 1/2 on the front, but it rubbed to much when turning, so I raised it 1/4". Also, the car has a natural body rake when the front and rear fender gaps are the same, so I didn't want to overdo that. I've been surprised at how drivable my car is just about everywhere. I don't bottom out on dips/speedbumps, and I don't have a problem pulling into driveways. I like that I can ride this low and still maintain full drivability.
Here are some more quick pics of the final stance:
Front close-up
Front close-up
LIRL @ biscuits...jowo...looks great man...i think i'm at 24" on the front and 24 3/8s in the back...on 18s...i rub..but oh well i like the look and i scrape...but oh well i like the look LOL.
SO WHAT IMA RICER!!!!!!!!
I'm pretty happy with the ride as well I must say. I like it a bit stiffer, so I set it on 14F, 15R, but if you soften it out a few clicks it becomes very comfortable. My settings aren't back-breaking, but they're not for your grandma's buick. So yes, my consensus is: great ride, great adjustability.
Yeah, it's true. I read probably every BC review on each of those forums. With the exception of one review, they were all VERY positive. The only one that wasn't was from someone who had a coilover snap in half. (could have been for any number of reasons/or just a freak accident, who knows) I just figure that any product that consistently gets the kind of reviews these do across so many forums must be good.
^yea man its definitely great for the money...my mom and wife really have nothing bad to say about the ride...only bad thing is im so low i have issues w/ clearance and my axles sound like choppas about to land lol. other than that, the ride is phenominal..has me so damn spoiled that im near breaking bank to get a set for my beater...and i said i'm only allowing 1500 to spend on it lol go figure
coilovers Vs. Lowering springs?
Hey Guys,
I was wondering what would be better ground control coilovers that go on stock struts or lowering springs?
I have a 2000 Nissan Maxima GLE and i just bought 18 inch rims with low pro tires on them and there is way too much wheel well left...so here are the things that i am looking for.
I have snow tires that have a massive amount of tread on them on the stock maxima rims so i do not want to rub in the winter.
i live in upstate NY so there is sand and salt out the ***.
i want to have a smooth ride.
i do not want my tires to wear unevenly.
i don't want to blow a strut because i am using a part of the strut that has not been used that much.
i do not want my front tires tucked to the point where i have to take turns like a tractor tailor.(the point of lowering a car is for better handling)
please let me know what is best for me.Thank you.
Hey Guys,
My second recommendation is for you to come to me to have the installation done. Not sure how far upstate you are, but if the trek is manageable, the cost savings and guarantee it's done properly is worth it.
just a 2" drop reference for GNU on a set of G35 18s i had w/ 245/40/18s (springs were DropZone)
the drop was ok, but i wasnt happy, i wanted to go lower so i eventually went w/ coilovers and slammed it
i run bc coilovers on my s14, witch has full suspension, minus flca, and rlca. i bought them for 900$ from importimage, looked in to getting fa 500, stances, and tein coils and for the price bc's offered more adjusting options, and i knew a few friends who had basic teins and where dissipointed for 1-1.2k they did not have adjustible upperpiller mounts ive probly put 1k on my 240 after the install and couldent be more happer with the set up im sure once i put a lot more miles on them i will have a better responce but even with the basic bc coils you have 32 way adjustments, and there fully rebuidable at about 100$ a peice so even if i only get 50-80k miles ill be happy with spending 400$ for the rebuild/ witch is about the same as oe struts
