Bank 2 Pre-Catalytic Converter Replacement
Old Jan 10, 2011 | 10:10 AM
dustey's Avatar
Has anyone successfully replaced the Bank 2 (radiator side) pre-cat with using the OEM gaskets?
I purchased an Eastern Cat (40387) and its not going to work (as some threads have concluded already) with the OEM gaskets. I am trying to find if any after market manufacturers make an actual direct replacement cat, identical to the factory one.
On DiscountCatalyticConverters.com, I found an "EvanFischer" brand cat that looks like it doesn't have the ring in the middle that the Eastern has which causes it not to work. Anyone ever tried this one?
http://www.discountcatalyticconverte...nts=partfinder
Old Jan 10, 2011 | 10:44 AM
VQP0WER's Avatar
FWIW, I replaced my precat about 2 months prior to my accident. I got the Eastman precat and did NOT install the OEM gasket. I did not notice any leaks and never had a problem.
Old Jan 10, 2011 | 10:47 AM
dustey's Avatar
Funny you say that. I was just thinking about that while I was writing up this thread. I just text'd my buddy who tried to install the Eastern this weekend and said it wouldnt work with the gaskets. I think he's tired of working on it. I know I am.
Anyways, I'd still like to know if anyone has successfully installed an aftermarket cat with the OEM gaskets and/or tried to EvanFischer cat.
Old Jan 10, 2011 | 10:51 AM
VQP0WER's Avatar
Too add, I even ground off those little "feet" on the OEM gasket. Though the gasket seems to fit in the precat, I had trouble with that whole setup mating up with the header flange.
Old Feb 4, 2011 | 03:03 PM
Rods03Max619's Avatar
Need to switch my front pre cat was going to order that Eastern one but in Cali and don't want nothing to happen, going to get headers soon so I don't have to deal with it and waste money seen a Magnaflow one that was 50 state legal...but my friend said just gut.the.front one and as long as I have the Fastcat you should pass smog but who knows...
Old Feb 4, 2011 | 06:25 PM
cabernet's Avatar
seen a Magnaflow one that was 50 state legal......
Do you have a link for the 50 state pre-cat? The only California cat I can find on the Magnaflow website is the regular cat.
Old Feb 4, 2011 | 08:11 PM
Seen it at carstuff.com for a 03 universal 50 state legal front 250 and rear 200 don't know if you would have to weld it in or not though but cheaper than nissan when its all said and done...
Old Feb 4, 2011 | 08:38 PM
And just called them they said its a direct fit....don't know about if they have for 00-01 gotta check...
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
Maxboy23
Aug 21, 2015 11:02 AM
1992maximase30
Aug 5, 2015 09:27 PM
