Which is the best intake for the AE?
Old Dec 20, 2001 | 05:31 AM
bramirez's Avatar
I am considering JWT or Stillen. I hear Stillen is more expensive. Any other recommendations? Which gives the most power for the $$$. Do you feel a significant difference after the install? Your comments are much appreciated.
Old Dec 20, 2001 | 05:51 AM
Cisco's Avatar
Re: Which is the best intake for the AE?
I went with the Stillen because it looks better, IMO. You feel a difference above 60+ MPH.
GC
Old Dec 20, 2001 | 05:56 AM
acMAX's Avatar
JWT and Stillen are almost exactly the same. Stillen has a better mounting bracket but that's really about it. Both give you the same performance gains.
I would have to say that Place Racing's cold air intake has the best sound, most expensive, and best performance gains.
Check out custommaxima.com. They sell the JWT and the Cold Air Intake by Place Racing at decent prices.
Hope this helps
Old Dec 20, 2001 | 08:06 AM
Adboy's Avatar
OSCAI
Don’t forget OSCAI… silly name for a really good, cheap intake modification.
Basically, you cut a hole in the bottom of your stock intake box, run a shop-vac hose to under the car, and get a K&N panel filter.
Total cost: Less than $60.
Benefits: Same high-end performance gains (so I’ve heard) as JWT or stillen, but without losing some low-end torque as you do with those cone intakes. Also, a benefit for me was no banging around near your MAF sensor while trying to install- and it looks stock.
Took me 15 minutes, and I suck at that kind of stuff.
Do a search, you’ll find lots of info about it… although, it seems like everyone forgot about it recently. If there’s a reason for this, please let me know guys.
I felt a noticeable- but not drastic- improvement at highway speeds. Almost no noise difference at all.
FYI:
2K1 AE 5 speed, OSCAI, Y-pipe and a brand new set of Nittos.
Old Dec 20, 2001 | 10:32 AM
bramirez's Avatar
Thank you:
Adboy
acMAX
Cisco
I'm going to look into the OSCAI and Place Racing and do some comparing.
Old Dec 20, 2001 | 10:44 AM
PhatGuy
Hey mon! Haven't "read" from you in a while!
Between the Stillen and JWT I would go JWT. I went with Stillen way back when I didn't know better. Both perform the same. The JWT is cheaper. And both can be cleaned with the K&N Cleaning kit.
Be sure to post up at the Canadian Roll Call at:
http://forums.maxima.org/showthread.php?threadid=85319
Old Dec 20, 2001 | 11:10 AM
bramirez's Avatar
How about the K&N??!
Old Dec 20, 2001 | 11:20 AM
PhatGuy
Re: How about the K&N??!
K&N drop in filters don't do jack in my opinion. You can probably pick up a used JWT or Stillen in good condition cheap. Keep an eye out on ebay and of the for sale forum.
Old Dec 20, 2001 | 11:55 AM
BigDogJonx's Avatar
Re: Re: How about the K&N??!
I dont find that true, I put in a K&N panel with my 3" OSCAI and I noticed a tad jump off the line. Not much but I noticed no lag time.
Coupled with an OSCAI and their is a big difference.
Old Dec 20, 2001 | 12:52 PM
PhatGuy
Re: Re: Re: How about the K&N??!
Yes with OSCAI there would be some gains. On their own with totally stock intake they don't much at all.
Old Dec 20, 2001 | 01:11 PM
jderry3's Avatar
Re: Re: Re: Re: How about the K&N??!
Mine.
Here are some pics. It is all homemade.intake
I will answer any questions you might have about it.
Old May 31, 2008 | 09:17 AM
mist max2000's Avatar
dude.. warning you as a neutral friend.. dont bump your posts to get 15 or u will get banned,.. good luck.. mods- lock?
Old May 31, 2008 | 05:50 PM
SoonerFan's Avatar
Cletus
Originally Posted by Backasswards
could you please make a new thread for me regarding my concern about the alpine iva-w205 in a 2004 Maxima. Thanks mist max2000
so you dont even have a 5th gen but you are bumping a 7 year old thread in the 5th gen forum...just to get to 15 posts...to start a thread about a topic that has been covered
Old May 31, 2008 | 06:12 PM
SoonerFan's Avatar
Cletus
if this has been covered then could you please link the thread or tell me the outcome? I dont spend much time in front of a pc so forums are a totally new source of information for me. Once again I am sorry for being new
go post in the proper place
6th gen
or
audio
Old May 31, 2008 | 06:28 PM
VQP0WER's Avatar
You already posted in the audio section. How many places do you need to ask?
http://forums.maxima.org/showthread.php?t=552035
Old May 31, 2008 | 06:36 PM
SoonerFan's Avatar
Cletus
post has been made in what I think is the right place which is where my first post happened to be. If you know the thread with the info I need could you please help me and post it in the audio thread I commented in?
since you already posted in the correct place...why did you bump a 7 year old thread in here?
you are clearly lost...go ***** up your forum
Old May 31, 2008 | 07:50 PM
irish44j's Avatar
retired moderator
now you are back to 5 posts. Stop PWing, and post in the correct section. I'm sure you can go get 15 posts in the Canada section pretty easily. Just go "talk to people"
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
