2002 & 2003 HID Help
So after the past years I have had several HID bulbs on my maxima and all of them looked white to me! My first set were 8,000k which was white with a tiny hint of blue. After those burnt up, i decided to try 10,000k because it wasn't blue enough and to my discovery it was the same exact white color with a TINY bit of blue! I came up with the conclusion that the eBay seller i got them from had mislabeled it. Finally after a whole year later i stopped by a local LED/lighting shop to try 8,000k, 10,000k, and even 12,000k and they all gave the same white color light! My car is a 5.5 gen and is using the stock xenon kit. All i did was swap the OEM bulbs for HID bulbs. I was wondering if anyone else has this problem. Is it because our OEM ballast isn't strong enough to get to bring the bulbs to such a high temperature? Or are my ballasts screwed up?
Higher the temperature, lower the light output.
My headlights have a tiny bit of blue, IMO, and they're 4300K.
"Test" them out at night, probably be more apparent, the blue that is.
You have clean, tastefully-done, nice looking car from what I can see in your sig pic and your pictures from the high beam DRL thread. Don't ruin it with ricey blue headlights.
Throw a set of 6000k bulbs in there and call it a day.
i used to like the way my 10k hids looked but got over it pretty fast so got 6k.. i know 10k works on our cars (our ballasts are strong enough)
but like others said, anything over 6k ruins light output and looks ricey
Go to www.3Bspec.com, Who is also known as Operatic here on the .org. You can get D2R's custom made to the I guess the Police blue color your looking for. Usually 10K has the right amount of blue to it. By the way, any oem ballast is strong enough, they are the best ballast you can have, I even recommend them for a retro fit.
Why do you care more about what color the lights are than you do about light output? I really don't understand that. The whole purpose of HIDs is to put as much light on the road as possible and thats what 4300k bulbs do.
Its amazing how many people on the road don't get this. Just this morning I was followed on the freeway by a guy in a Tacoma with the ricey blue headlights blinding in my mirror. Felt like slamming on the brakes just to bust those freeking things!
I only ask b/c headlights (no matter the kind) that aren't properly aimed can give off a hardcore glare of color (which can appear brighter than the respective kelvin the bulb is in)
Lol @ 12k lights looking white! If that's the color you like then regardless of what others say...it's the color YOU like.
t:
I got 8000k got a little blue look way more than my stock ones but want the 5000k to get better visual...especially when it rains...
Just a little info for anyone that didn't know:
The degrees K (Kelvin) that a bulb is labeled does NOT denote the actual temperature it burns at, or have anything to do with the amount of current needed to make the bulb operate. They're just labels to make it easier to denote one color bulb from the other.
HID kit bulbs are actually given their colors by using different elements. The way an HID bulb works is that the electricity is arced through a small tube filled with a gaseous form of an element. These ions are excited by the electrical current and glow, resulting in the color you see. For example, 3000k bulbs are actually filled with sodium ions. Sodium turns yellow when excited.
Xenon gas, when excited, burns that white-blue we get from the 4300k bulbs. Hence HID "xenon" bulbs. If you really wanted to, you could run a Neon HID kit, and have red HIDs.
So in other words, really, any decent ballast can run any bulb. They all take the same amount of voltage to ignite and run.
Do they look the same from whatever height you're looking at (looking from the top-down vs. eye-level/straight-on etc.)?
Yeah, they look the same from every angle
Yea seems like ur ballasts arnt working properly, im guessing its liek when you first turn on your lights its white for that split second then changes to the blue'r color...have you had your lights out of the car? any chance of pinched wires maybe a loss of ground somewhere would affect this??
xenon is far better then hid IMO..i have 02/03 hids on my 00 max se...and honeslty when i see hids on cars or just silly cars it makes me chuckle..
also side note--------> stock nissan oem factory xenons are 4300k or 4200k idk i cant remember which one but thats more then bright enough too see the road.
i actually dodged a deer on a busy road that was a long hilly stretch and was moderatley fast speed limits. I was going 45-55mph and a deer ran out in front of my car it was halfway accross my lane getting ready to go accross the yellow line..I swerved into oncoming lane immediatly my instincts kicked in and I dodged it by a hair. Idk how i did it or why i didnt hit the brakes but, one way or another I saved the day... Wow im a good driver kudos to myself and even more kudos to the maxima making it thru it. Afterwards I was so fking amped up I had to calm myself down..bc I had just 700 dollars worth of work done on my headgaskets and just got my max back after 3 days. I think maybe because I had my xenons on the deer backed down lol...or was intemidated. I cant remember if the deer crossed the road in front of my car or behind my car but im pretty sure it passed behind it because it happend in a split second...like the blink of an eye. But either way the maxi came out alright and so did I ;-)
and btw xenons IMO are more then bright enough to see..hids are just silly theyre almost to blue and ricer looking............xenon all the way! :-P
also side note--------> stock factory xenons are 4300k or 4200k idk i cant remember which one but thats more then bright enough.
and also more then bright enough to see..hids are just silly theyre almost to blue xenon all the way! :-P
+3
It's all good. You can just replace the term 'hid' with 'hid-like blue-coated bulbs' in your earlier posts and it would hold true for the most part.
I mean, not to be a ****, but I'm not even sure where this idea that there was some kind of difference between "xenon" and HID lighting could have come from.
Hid lights, where to get cheap ones online? It's 100 at discount auto.
Well the bulb blew, the high beams still work.
Bump
Bump
Do you need the bulb or what?
Where would be the best place to buy a replacement D2R bulbs in say like a 6000k temp? I've dealt with DDM tuning on several cars for complete kits and they have replacement bulbs for cheap, however they are wired up to work with aftermarket ballasts therfore it wouldn't work on the factory Maxima one. I ordered a 6000k kit for the fogs and I want the headlights to match as well.
Unclejunebug
Apr 2, 2016 05:42 AM
MaxLvr21
Oct 17, 2015 12:11 PM
