Klunking noise from suspension....who wants to throw the next dart.
Old Jan 22, 2011 | 09:20 PM
geenowalker's Avatar
changed struts, bushings (new lca's with Energy Suspns), brakes (routine), cv's. Who wants to throw the next dart? Klunking is driving me friggen nuts. Does seem to be lessen while driving (as opposed to coasting).
thanks for any suggestions...
g
2000 SE, auto, 233K stock.
Old Jan 22, 2011 | 09:24 PM
Wheel bearing?
Old Jan 22, 2011 | 10:09 PM
nelledge's Avatar
"I'm just sayin'..."
g
Check tierods, balljoints, sway bar end links, and strut mounts.
Old Jan 22, 2011 | 10:14 PM
junglee Z's Avatar
i read in many of the "klunk" threads that it could possibly be the upper motor mounts. my I35 has the klunk everyone hates. i've changed a few suspension parts but nothing solved the issue. only thing left to do is lca bushings from energy suspension. i don't exactly know how motor mounts would cause the klunk but what the hell. i'll be doing it soon
Old Jan 22, 2011 | 10:17 PM
Scottwax's Avatar
That's Mr. Detail to you
Passenger side engine mount.
Old Jan 22, 2011 | 10:21 PM
CMax03's Avatar
The upper passenger side Motor mount is notorious for sounding like a suspension item but it's not....small bumps (ripples) seem to exaggerate the mount to sound like a bad strut mount.....Get a big screwdriver/out and pry @ it or call me I'll check it out for you Junglee Z
Old Jan 22, 2011 | 10:38 PM
LETINES's Avatar
Where do you live G ? Here in the northeast my 2000 has major rust problems. The radiator support separated from the center beam and was making some srange sounds, not too safe either. My 02 se looks like it spent about a year submerged in salt water, oil pan already had to be replaced but I did some undercoating and rustproofing, hopefully will help. Also could be motor mounts as stated above. I suck at darts btw
Old Jan 23, 2011 | 05:06 AM
Rochester's Avatar
Don't suppose you've ruled out the exhaust? If your engine torque mounts are getting sloppy, the added play as the engine rocks can sometimes cause the exhaust to knock against the frame when you hit just the right resonance. That was the indicator that led me to replace the torque mount bushings a couple years ago.
Old Jan 23, 2011 | 06:17 AM
jeff5347's Avatar
+3 on the pass motor mount. I had a squeak and light klumking sound. Got on the pass side and bounced it up and down and the noise is my pass side mount. WD40d it and the squeak went away but the klunk is still present. Not gonna attempt a fix until spring since it is in the single digits today and future.
Is there a ES replacement for the pas motor mount?
Old Jan 23, 2011 | 06:24 AM
Rochester's Avatar
Man, that question gets asked a lot.
I'd much rather cut out the originals, powder-coat the mounts, and press in something from ES.
I wonder if ES knows how often someone asks that question?
Old Jan 23, 2011 | 07:08 AM
byrdman164's Avatar
I know I'd be in for an ES replacement...the clunking is very frustrating
Old Jan 23, 2011 | 01:34 PM
thanks for hte responses.
Just replaced the bushings with ES's. New Tie rods at hte same time. Will try the engine mount and sway bar check next. Thanks again for the advice.
Old Jan 23, 2011 | 02:10 PM
BigLou55's Avatar
strut mount...its usually the culprit...its best to always get a new set of them when you replace your struts
Old Jan 24, 2011 | 10:59 AM
asianstyle's Avatar
g
let me know what you find out. I have the same clunking noise/squeak. thinking about replacing some of the parts you did but am a little low on $$$.
Old Jan 24, 2011 | 11:01 AM
phatboislim's Avatar
x2
Old Jan 24, 2011 | 12:33 PM
djfrestyl's Avatar
Suspension Yoda
In addition to everything mentioned here, it could also be your lower radiator support rusted through, motor mount crossmember clunking around.
Old Jan 25, 2011 | 05:40 AM
Rochester's Avatar
With solid poly torque mount bushings installed, that (probably) rules out exhaust banging. And new outer tie-rod ends rules out that component.
So... where are you now with this problem?
Old Jan 25, 2011 | 08:57 PM
StevieB's Avatar
233K
At 233k I'd have to guess your engine mounts are due for a refresh. I just changed the torque mounts, and will do the passenger mount later this week. I got the set of 4 EBay mounts(auto), 3 of which I can use being a manual.
My old mounts seemed fine visually, but the front one was separated in 2 pieces, and the back one was close behind...on a car with 110K miles. I'm expecting the passenger mount to be shot too, as I'm still getting some clunk, but it seems to be localized on that side now. The vibration issue I had on acceleration is now resolved with the 2 new mounts. I'll also be changing the swaybar endlinks for Moogs, which are beefier than stock (my previous Max's klunk was eliminated this way) as well as the swaybar bushings (ES) because I figure they're due after almost 10 years. Given your mileage I'd get the EBay mounts and change them all, which you can do since you're auto- it's just too common for our cars to have trashed mounts past 100K miles. After that I'd look at the endlinks.
BTW, what djfrestyl said about the radiator support..if you change your mounts, before you remove the crossmember, check the lower radiator support carefully so you don't get a bad surprise.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
maxinout93
Oct 31, 2015 02:04 AM
uttadms31
Sep 30, 2015 05:24 AM
