Dashboard clock doesn't work and odometer resets to 0 each time I turn the car on
Old Jan 23, 2011 | 05:41 PM
BigOgre's Avatar
Does anyone have any idea what happened or how to fix it?
Also, I installed a new dome light I got from eBay - maybe that could be the problem
Old Jan 23, 2011 | 05:49 PM
Ghost_54's Avatar
That would be a good place to start, reinstall the original dome light and recheck all fuses are working to see if things return to normal. Possible that the new dome light is drawing more current than the original OEM one, however I am stumped as to what relationship the dome light would have with the clock and your odometer resetting to 0.
Old Jan 23, 2011 | 05:50 PM
BigOgre's Avatar
Im going to go take the light out right now, will report back soon
Old Jan 29, 2011 | 08:50 PM
BigOgre's Avatar
Bump.. Removed the lights and all the fuses are good.. any other ideas?
Old Jan 30, 2011 | 09:33 AM
Govols83's Avatar
I actually had this problem recently. My problem was the battery connection on the positive terminal. It didn't drain the battery or anything, but it did reset my trip back to zero and mess up the time on my clock. You might want to check that.
Old Feb 3, 2011 | 04:04 PM
BigOgre's Avatar
I checked that.. its all good.. any other ideas?
Old Feb 3, 2011 | 07:11 PM
Nopike's Avatar
The clock and the odometer have a battery backup circuit that saves the settings. The fuse for it is #12 value of 10 Amps. Although if this fuse is blown a few other thing like your clock security indicator lamp, NATS and what Nissan calls the board computer would also not function properly. It looks like it would also effect the memory of the Heating and AC setting and your phone power jack as well. Also you auto seat positioner memory if you have that feature it would not work.
Old Jan 3, 2015 | 08:35 AM
Dcmarti1's Avatar
I have same problem on 2000 maxima. Clock, security don't work. Odometer rests every time start car. Electronic parts fuse blows every time I replace it
Old Jan 4, 2015 | 12:01 AM
DennisMik's Avatar
You have to figure out what is blowing the fuse. Easiest thing to start with is to unplug the clock and see if the fuse still blows.
jerrod99_se-l
Aug 27, 2015 08:27 PM
Flores94
Aug 13, 2015 01:17 PM
MikesChevelle
Aug 9, 2015 11:50 AM
mrgooch
Aug 9, 2015 11:00 AM
egali045
Aug 5, 2015 09:02 AM
