Symptoms of bad flex-section vs. CC???
Old Jan 31, 2011 | 03:38 PM
mannetti21's Avatar
I'm getting a rattle at 1900rpm (although typically around 1900rpm, it seems to be vibration dependent more so than rpm dependent), occasional rotten egg smell with hard accel., and seems like general loss of power most notable 1500-3500rpm.
Also, gas mileage has been mediocre for a little over a year, but terrible in the last 5 months or so, around 180-200miles per every 3/4ths tank of gas. MAF is less than 3yrs old. Spark plugs about the same. Premium 93oct gas. Mobil One full synthetic.
Haven't had a chance to get underneath the car yet b/c of a crazy work schedule and $h1tty weather.
Does this sound more like a bad/clogged cat. problem? Or maybe a damaged flex section? Or neither?
Old Jan 31, 2011 | 03:40 PM
Because of the smell and bad MPG I'm guessing it's a cat problem.
Bad flex sections might rattle but you won't get that rotten egg smell.
Old Jan 31, 2011 | 03:43 PM
mannetti21's Avatar
The egg smell isn't real strong, but faintly noticeable. I'm wondering also if, besides the egg smell, a hole in the flex would cause similar symptoms.
Old Jan 31, 2011 | 08:50 PM
yankeefan13's Avatar
Yeah with that bad mpg I dont think the flex would be causing that. So it would probably be the cat.
Old Jan 31, 2011 | 08:52 PM
Stormzusmc's Avatar
get obx headers and have a shop replace the cat with a pipe..problem solved
Old Jan 31, 2011 | 11:11 PM
mannetti21's Avatar
any emissions testing issues with that setup?
About how many hours should a shop be charging for a header and cat replacement?
Old Feb 1, 2011 | 12:03 AM
Stormzusmc's Avatar
No clue - here in MN we don't have emissions laws, I don't have a check engine light though.
Header install is a cake walk - people on here are girls about doing it themselves, you just have to have tools. The cat..honestly you can buy a test pipe instead of going custom.
A shop could do it in 5 hours maybe with any unexpected issues. It took me 6 with beer/breaks and I had to weld a new bung and grind a few things myself..otherwise it was easy.
Old Mar 29, 2011 | 10:04 AM
Prophecy99's Avatar
OP did you do anything about this?
chisam14
Nov 6, 2018 08:56 PM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
zmcneely13
Sep 26, 2015 02:26 PM
