Tired of sanding down ugly yellow headlights!!
My headlights look so nasty in the sunlight with all that foggy yellowness!
I've tried 3M headlight restorer and used a buffer to polish with the compound but it comes back after a few weeks/months. Eventually i'm gonna run out of headlight to sand!
Do you guys know of any company or any way to buy the headlight lenses by itself without the whole assembly? Would be a lot cheaper than the $300 per headlight price online. I don't dig those eBay halo headlights either cause i personally dont like the way they look
Unless someone has tried buying those cheap headlights and swapping lenses with the OEM headlight. Does anyone know if the eBay lights are the same fitment/size as the OEM?
i have the same problem with my headlights as well..the only thing you can do is open it up and clean them and restore them from the inside out..thats what i am going to do..eventually. But i am too scared to bake them and pry them open idc enough to ruin the headlight over a little fog and condensation. Its a result of the headlight not being properly sealed..i would just buy another oem headlight NEW this time or find a used one but slightly used..thats you're best bet.
I bought this LightRite that I found in this thread, but haven't had a chance to use it yet.
http://forums.maxima.org/7808219-post33.html
http://forums.maxima.org/5th-generat...-included.html
If you've used all those and they're still yellowing then your problem is probably on the inside of the headlight. Bake them open and work from in there. Then seal them back up real good because you probably have a crack in the seal somewhere that's allowing condensation to build up on the inside.
While you're at it, paint your housings and clear your turn signals. It'll make the effort of opening them up worthwhile.
Take a look at this thread, it explains everything:
Another 5th gen down...
I thought the pic actually looked kinda badass when I cropped it down like that so I decided to sig it.
I bought a set locally and purchased a headlight cleaner that actually worked. This stuff smells strong and probably has something similar to PVC primer as an ingredient. I've only had to clean mine one tiime.
I guess i'll bake them and try cleaning them from the inside. Yeah it probably is condensation since i did a poor job sealing them.
As for swapping lenses from the $100-$200 ebay headlights has anyone tried?
After sanding and polishing your headlights, Apply some 3M clear bra to them to protect against future chipping, and fading. I've done this with all my cars, and to many many of my customers cars as well. When it's done, you can't even tell it's there. There's nothing better. Any tint shop that does that clear bra should be able to apply it for you, or sell you enough to get the job done. Here's my 5.5 right after I cleaned them up, and applied the film:
if its the yellow **** on the outside, use the turtle wax headlight restore kit. it worked for my 00 sentra. couldnt even see through them and i cleaned it to almost a brand new finish. no sanding required, just alot of pressure and a nice microfiber towel
you will see layers of the yellow coming off on the towel...if you are not using a yellow towel of course
Clean, wet sand with 1000 grit, polish, and apply Lamin-X will be my route.....I've cleaned them really good b4 and within a few months it's looking a little hazy again! Never heard the name ClearBra but it's probably all the same....I did a laminate protective film on my fogs 7 years ago and they still look brand new!!!!!!
Where do you buy your supply from? Do you have an internet link available?
I work for a distributor that deals with a lot of automotive reconditioning products. I use a surface protector sealant on my headlights after almost every wash. My car is 11 years young and headlights appear brand new.
Here is a link to one of our distributors, you can possibly get it from them, or PM me and I could help you out.
Very good stuff.
Scroll down to "TEC 595 Super Blue Surface Protector"
http://downloads.ecpinc.net/pdf/Cata...t_Finishng.pdf
Very good stuff.
There's also a kit that has a cloth ball type item you put into a drill and that'll cut down on the sanding time. Follow up with Plastic X to polish and after you can always hand apply some regular old wax to seal the plastic. Or just go the film route once done with the sanding/polishing.
WOW! that looks amazingly clear! Never knew a clearbra would prevent it from further fading cause i thought it was also caused by the sun. i'l try it soon!
Check out LightRite................
http://www.youtube.com/watch?v=nXc6V9PyRak
http://www.youtube.com/watch?v=w6H-n...eature=related
I got a new set on ebay for 100.00$
http://shop.ebay.com/?_from=R40&_trk...All-Categories
and fogs for 80$
and fogs for 80$
Never had that issue happen. The body shop that I work at does this as a part of their headlight restore package they offer. We use PPG automotive clear coat.
The headlights can be restored using any method you like, but the ONLY way to keep them from fading again is to apply the 3M clear film. The reason the light won't fade after the application of that stuff is because now you've successfully put a physical barrier between the light, and the outside elements. The UV won't hurt it, and neither will the stones and road debris. I also applied it to my glass fogs. They were new, and I wanted to protect them from chipping. It's better that way becuase IF they get hit by a big rock, and it cracks them...the clear-bra will prevent water from getting in, and then I won't have to buy new ones lol. I suppose I can handle a crack in the fog....but I can't live with one full of water, and rust, etc.
Applying clear coat to the headlight is no good IMO. It might look OK at best, but it'll still get chipped and pitted. Plus it won't look as optically clear.
I buy my clear-bra by the role, because I also apply it to the freshly painted front ends.
AaronL
Nov 15, 2020 11:52 AM
doctorpullit
Jul 20, 2019 09:31 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Serotta33
Sep 17, 2015 12:14 PM
