Cold Start Problem with video
Since its been getting colder the cold starts have been getting worse. At start up the car revs itself up to 1500 rpm and idles there for about a minute before it goes back down to about 800 rpm. Then it sputters like its about to turn off and sounds like its revving even though it is not. If I drive off when its cold while stopped in traffic it jerks forward as if its trying to drive off or as if someone rear ended me but the rpms remain constant, so its as if its revving when really its not. I've posted a video of it after I had just started it for about 2 minutes. Car is a 2000 auto has 185k and no mods other then an aftermarket muffler that previous owner had put on since the original had a leak. I also found a stain of what seemed like coolant under the passenger side this is the first time I notice it. Btw car does turn off sometimes right after start up when it sputters.
The video is not the best but you can hear when the car sounds like its sputtering/stuttering, also theres an "electric" whistle sound you can hear, this is the first time I hear this but its sounds like a buzzer
Based on your tem gauge the engine is not completely cold.... and no SES light... I would say start with the leak ... it might just be coolant hose. Also check to see if the coolant is full... other than that drive it until the SES light comes on and then check the codes..
IACV? They most commonly go bad after a good freeze which freezes the IACV housing which is bolted to the bottom of TB. The gasket between the 2 is not cold friendly. Easiest way to check this would be to remove your intake piping and look into your throttle body before the butterfly and see if you see any engine coolant.
i dont have a 00vi but... i would have to say the IACV as well, im not sure if its different but i would try cleaning it first
its probably your lower intake gasket if the IACV doesnt solve your problem. replace the lower gasket and you should be good to go
This video is from a few hours later at initial start up.
As you can see the idle climb back up after coming back into park from drive etc.
This next video is 5 minutes after the above one.
As you can see after it warms up everything is fine.
Coolant circulates thru the IACV for cold start and once the water is warmer than the air it is used to change the air temp of the air coming in thru the iacv via sourcing coolant from the main heat source (combustion area)It's a preset idle to faster warm your car up to normal operating temperature on them cold colddays. There are no IACV adjustments but I believe you can take your negative cable off for thirty minutes and when you crank it again your ecu will learn the idle all over again via computer. It's just going to drive like that when in that mode. Most likely til the thermostat opens or close. / fill your motor mounts solid
100% sure on this one trust me thats your problem
dealer part only
its about 60-90 bones
labors not bad about 3 hrs tops just dont forget those stubborn manifold bracket bolts THEY SUCKgood luck dude post back when everythings peachy
i may have this problem too on my 2002, but its only immediately after cold start ups, no problems after running for more than a min or 2.
do the NWP spacers replace the lower intake gasket? ( im guessing not) :dumb
So I looked at autozones website and would something like this be sufficient considering it has all three gaskets
http://www.autozone.com/autozone/par...8854_207134_0_
or this felpro one
http://www.autozone.com/autozone/par...89_46006_5297_
or this felpro one
and be sure to torque everything in the proper sequence and spec or you will have a leak for sure
i dont know too much about the 3.5s but spacers without gaskets= problems
You can always test that gasket by having someone watch the tachometer while you spray hairspray or starting fluid where you suspect the gasket not sealing. Be sure to communicate with someone with car experience inside the car that is familiar with the situation. I wouldnt dare get my wife to help me
If you see an RPM jump bigger than your already seeing in the cold. It's leaking. It's getting unaccounted for air into the intake causing - MassAirFlowSensors, IntakeAirTemps. ThrottlePosition & IdleAirControlValve to all have inaccurate readings and at risk of detonation. A known head gasket killer and the cold is no joke and not on the HEAD GASKETS side for winning. I lost a head gasket just this morning on a different vehicle of mine
Best of luck.
Best of luck.
Im going to clean out the IACV and TB tomorrow, hopefully that does the trick. I recently replaced the water pump and wondering if theres any correlation.
Just earlier today, when I was driving . . I noticed the engine was struggling and shaking. Not looking too good for the VQ.
Lakersallday24
Nov 7, 2024 07:31 PM
tsi6001
Oct 3, 2022 10:23 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
