check engine light has a "faint glow", any ideas?
Old Feb 10, 2011 | 10:47 AM
bigorangexj's Avatar
Im looking to buy 2002 maxima GLE today and car looks drives great , but there it very faint glow coming from behind the check engine light. it is not fully on like the seatbelt light but it is something I am definitely something I am concerned about. they are going to run an obd scan b4 I purchase but if it doesn't pull any codes should I be worried about it being some other issue? anyone have any experience like this?
Old Feb 10, 2011 | 10:50 AM
zzmmrx0xmzz's Avatar
Did you install any new LEDs or any new lights on the car? I remember after installing LED lights on my doors my check engine light would have a faint glow.
Old Feb 10, 2011 | 11:15 AM
I didn't buy the car yet, put deposit today and driving there to pick up right now. nothing aftermarket at all that I can see
Old Feb 10, 2011 | 11:50 AM
maxima dude's Avatar
^^ why not plug in a scanner and see if theirs any codes first... sounds like your gunna buy a lemon to me... ask the sales person why its doing that
Old Feb 10, 2011 | 12:08 PM
they will be scanning it, but if no codes should I still worry
Old Feb 10, 2011 | 02:26 PM
mrpopo573's Avatar
I'd be more worried about an actual inspection of the car's mechanical condition, but always pull codes, and if there are none, then you have one less thing to worry about.
Old Feb 10, 2011 | 02:44 PM
boondoxmax's Avatar
It was a know problem with 02 maximas. When I brought mine new in 02 the dim light check engine light was showing at night. I took to dealer and the knew exactly what the problem was. Some gauge clusters on 02 maximas are defective and they replaced my gauge cluster and problem was solved. Don't buy it unless the replace the gauge cluster because its very expensive. Mine was done under warranty but if I had to pay it would have cost me 800.00. Its harmless if you just wanna not have it fix.
Old Feb 10, 2011 | 02:45 PM
LETINES's Avatar
Be afraid, be very afraid
Old Feb 10, 2011 | 02:48 PM
6SPD02SE's Avatar
Mine does the same thing. Nothing wrong with it. Very faint glow from the other lights in the guage cluster. Has nothing to do with the actual check engine bulb.
Old Feb 10, 2011 | 03:23 PM
Froggmann's Avatar
Even if the dealer doesn't want to replace the cluster as long as the car is sound go ahead and buy it anyway. Mine has this defect and it's a non-issue for me. I recall seeing a TSB on the issue but now I can't find it.
Old Feb 10, 2011 | 05:53 PM
realtor's Avatar
I agree. When I bought a new '03 years ago, the same thing happened to me. It will not throw a code at all. It was something bad with the instrument cluster and the nissan stealer replaced it under warranty and re-calibrated the new odometer with the same miles as the old one. Good luck.
Old Feb 10, 2011 | 05:56 PM
thanks a LOT. i actually didn't see most of these posts until after i purchased the car. i was right next to the mechanic (w/out the salesman nearby) and every single system check came back w/out any codes. i guess i'll just live with it, as long as it comes on solid when there really is an issue. anyway, didn't get a steal on the car as i usually do, but i was very picky about color/factory options, etc. so i am happy and hope she will serve me well to 200k+ like my '96 did. look forward to becoming an active member of the community and already have a short term to do list (oem spoiler, mile-range starter, tint). probably bigger plans later on as i am a recovering modaholic.
Old Feb 10, 2011 | 06:19 PM
azdevils013's Avatar
Mine did the same thing when I put cathodes in.
Old Feb 11, 2011 | 11:25 AM
ewakefield's Avatar
my 03 does that. no codes.
Old Feb 11, 2011 | 11:59 AM
Intrepid1's Avatar
I'm thinking you take a small piece of duck tape and fix er up that way. Outta sight, no worries!
Plus this will give the car character and that lived in practical flair everyone needs
Old Feb 12, 2011 | 09:44 AM
mrjones's Avatar
My 2k2 does this too; i figured that if there truly was an SES light then it would light up bright just like any other light on the gauge cluster. I'm glad you posted this because mine has been doing this for a some time and i was skeptical and didnt realize it was a defect with the gauge cluster. I'm currently at around 81K.
Old Feb 12, 2011 | 02:22 PM
jeff5347's Avatar
I wouldnt worry. My 03 does the same thing. Not all the time but once in a while it has a faint glow. I assume it is from the other dash lights creeping in. Mine has no codes as well
Old Feb 12, 2011 | 06:32 PM
off topic now, but just curious, i really want to swap out tail lights to the ones with the darker/black "racoon eyes" with with white top half of the circle and clear bottom half is this from an '00/'01 or are they aftermarket or do i actually have to paint or tint the lenses. first thing i really want to get done and oem wing/tint
Old Feb 12, 2011 | 11:49 PM
mahanddeem's Avatar
just a dump stupid post without any clarification why "be very afraid"
fail.....
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
