wheel upgrade question
Old Feb 23, 2011 | 03:38 PM
gotendbz1's Avatar
I just upgraded to 18" wheel and the wheels are resting only on the 5 studs instead of the hub. Is this safe and will it cause any problem?
Old Feb 23, 2011 | 03:43 PM
NmexMAX's Avatar
dot dot dot ...
That doesn't seem safe.
Is it because the bore is too small on the new wheel or because your studs are too long for your lug nuts? That will freak up your wheel if you drive around on it like that for any length of time. Happened to me once. The stud mauled the stud hole in the wheel, and after that I could never get rid of the vibrations.
Needed to get a new wheel.
I would try and see what you can do to make it fit correctly.
Old Feb 23, 2011 | 04:03 PM
gotendbz1's Avatar
the bore is 2 big on my new wheel, what do i buy to fix this or what shop does this type of stuff?
Old Feb 23, 2011 | 04:12 PM
NmexMAX's Avatar
dot dot dot ...
It should fit fine then. If the bore is too big on your wheel, your wheel should slip right on the bore on the car. What's preventing it from sitting flush?
Are you sure you got the correct bolt pattern? (5x114.3)?
Old Feb 23, 2011 | 04:34 PM
gotendbz1's Avatar
bolt pattern fits fine. but since the bore on the wheel is bigger than the hub it is no longer being support by it.
Old Feb 23, 2011 | 06:35 PM
cmax1's Avatar
get some hub centric rings. they take up the space between the hub and the ring to center the rim perfectly..
Old Feb 23, 2011 | 07:18 PM
mrjones's Avatar
gotendbz1, what wheel brand did you upgrade to?
Old Feb 23, 2011 | 07:30 PM
Sounds like the center bore is too small and isn't going onto the hub. I had that problem with some rims I bought off of a Camry a while ago for the winter.
Old Feb 23, 2011 | 07:52 PM
zero2sixtyZ's Avatar
You embarrass me.
Like cmax said, hubcentric rings. They are meant for wheels with a larger center bore, typically aftermarket wheels to remain universal, to match with a hub.
Old Feb 23, 2011 | 08:39 PM
gotendbz1's Avatar
hub centric rings is what i need. now what stores locally can i get it from. Im in nyc> i searched and can't find anywhere but online.
also can i still drive the car without the rings? still safe?
Old Feb 23, 2011 | 08:51 PM
maximo018's Avatar
Not recommended sir. https://www.justforwheels.com/index.jsp This is where I got mine from. $35 all 4 shipped.
Old Feb 24, 2011 | 06:16 AM
NmexMAX's Avatar
dot dot dot ...
Toss your old wheels back on,
Purchase rings
Wait for shipped rings
Profit???
HOKUSMAX
Nov 13, 2017 04:34 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
Dasmith
Aug 25, 2015 10:15 PM
sonic7
Aug 20, 2015 12:23 PM
BassAddictJ
Aug 4, 2015 11:38 AM
