what is your 0 to 60 time????
Old Feb 24, 2011 | 05:00 PM
getflushed's Avatar
Hey guys!
I'm curious on what your 0 to 60 times are?auto? Manual? Stock? If not list your upgrades.
Mine is 9.86 seconds which seems really long. I have read that the auto trannies still get 0 to 60 in 7.6 seconds and the manuals are like 6.7 seconds
Anyways just want to get an idea of an average timing for. The max!
Thanks guys!
Old Feb 24, 2011 | 05:42 PM
LI_Max_WOT's Avatar
my intake mod... good or bad? videos inside
i made this youtube account to track some progress with mods and stuff so i have some sort of record cause i probably wont ever hit a dyno...
anyway i timed 0-60 in 6.7s launching in second because i didnt want to crash and wanted to film something...
also theres a freshly installed custom installed cold air intake on there, my only mod so far since i just got the car in december 10', let me know what you think of that if you check out my 2 current videos
pertinent facts: 03 maxima se 6 speed every option, probably around 70-80 lbs of soundproofing and audio equipment extra in the car
http://www.youtube.com/user/the2k3max?feature=mhum#p/a/u/0/bu7F8k_J5N8
Old Feb 24, 2011 | 06:00 PM
Grand_hustle17's Avatar
......................... (who here can really test their 0-60 accurately???)
Old Feb 24, 2011 | 08:31 PM
perkman87's Avatar
I can. I just borrow the computer from the shop. its in the shape of a v and goes on the windshield. I cant recall the name of it but it measures a bunch of parameters.
Old Feb 25, 2011 | 06:27 AM
Gizm0's Avatar
Here is my time... I know dumping the clutch at 4K might not be very good for the car....
http://www.youtube.com/watch?v=-7Q9J_xXQ8o
Old Feb 25, 2011 | 04:41 PM
crazy97's Avatar
Originally Posted by getflushed
Hey guys!
Thanks guys!
Where do you live? Elevation can be a factor. The higher the elevation, such as Colorado, the less power you will have. The closer to sea level you are the better.
Old Feb 25, 2011 | 04:53 PM
getflushed's Avatar
I live in canada, in vancouver b.c. I am slightly above sea level, I actually just came back in my house from pulling out a 470 khm resistor it definitely has way more power when cold! Like a large amount.I get hesitation in the morning in low rpms that almost completely vanishes once warm but still there,I have long starts in the morning when cold unless my tank is above half full and ocasionally when warm it struggles for like 5 seconds once started. It feels like when I'm taking off from a light I'm having to floor it to keep up with 4 bangers..... I have no clue... I'm pissed
Old Mar 1, 2011 | 04:54 PM
schmellyfart's Avatar
I've pulled a few 5.5's before. Recorded the time with my E manage.
Old Mar 1, 2011 | 08:16 PM
perkman87's Avatar
Old Mar 1, 2011 | 08:17 PM
perkman87's Avatar
5.4 according to my iphone timer!!
Old Mar 1, 2011 | 08:41 PM
jowo9's Avatar
Which iPhone timer do you have?
Old Mar 2, 2011 | 06:32 AM
95VQ30's Avatar
Perkman- how do you do your jib shots in your videos? No way your hands are that steady
Old Mar 2, 2011 | 06:34 AM
NmexMAX's Avatar
dot dot dot ...
6.3 seconds @ 5600' elevation:
Old Mar 2, 2011 | 09:55 AM
Well I thought I had some 5.5's, I stand corrected
B-A= 0 to 60 mph/100kmh time. A and B taken from the table on the right.
5.84
5.74
5.34
Old Mar 2, 2011 | 04:16 PM
getflushed's Avatar
well i took it for a spin around the block a couple times the best i got was 8.35 secs.... i had a resistor in there and hooked up my odb II my timing in gear was 10-11 degrees when i took the resistor out... same deal 10 to 11 i guess my ks is good........ WTF!!!! why is mine so slow!!!!! when im in p its 15 to 16 degrees i gotta look at my manual to see the specific timing for idle i dunno im going crazy thoug i know that much!!!!!
Old Mar 2, 2011 | 04:27 PM
NmexMAX's Avatar
dot dot dot ...
Is your timing that way WOT, can you log it and was your time measured using the OBDII (VSS vs time)?
Do you see what I've done here?
schmelly FTW
Old Mar 2, 2011 | 05:18 PM
getflushed's Avatar
my obd-II is a cheapy so no logging, but ill do it the old fashoned way and write it all down lol, no it was more of me hittin the timer on my phone and mashing the gas at the same time.... yea i know not very accurate but i dont see me being off by 2-3 seconds.... im goping to go for a drive in a bit and write down all the readings and ill post it up here nmexMAX please help me on this one, by the looks of your above posting you seem to know your stuff!!!!! ill post back in a hour or so thanks guys
schmelly FTW
Old Mar 2, 2011 | 05:23 PM
perkman87's Avatar
I have a dolly. and jib.
Old Mar 2, 2011 | 05:24 PM
perkman87's Avatar
the one that came with it.....
Old Mar 2, 2011 | 05:27 PM
schmelly FTW
That was before the headers
Old Mar 2, 2011 | 06:27 PM
getflushed's Avatar
so heres what i got i know some might not be relative i just put them anyways
TIMING:
IDLE "P"- 15 C
IDLE 'D'- 11C
LIGHT THROTTLE (1/4)- 35C
MILD THROTTLE (1/2)- 35C
MID THROTTLE (3/4)- 34C
WOT THROTTLE- 20C
COASTING- 10C
INTAKE AIR TEMP SENSOR 11C (OUTSIDE TEMP 6C, ENGINE TEMP 80C)
FUEL:
LT FUEL- 77%
LT FUEL B1 AT IDLE-2.33 STEADY
ST FUEL B2- 3.89-5.45 SPERATICALLY JUMPS BETWEEN
ST FUEL B1- 3.11-4.77 SPERATICALLY JUMPS BETWEEN
WHEN NOT RUNNING IN ACC
IGNITION TIMING 63.5
TPS 3.13
MAF .13 G/S
schmelly FTW
Old Mar 3, 2011 | 05:47 PM
getflushed's Avatar
Bump
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
Wareagle92
Sep 3, 2015 07:18 PM
