View Poll Results: Do you have active OBDII codes, ie. A CEL/SES?
Yes, but I don't know what it is.
1.58%
Yes, emissions related (O2 sensors, Cat efficiency, etc.)
65
25.69%
Yes, engine related (Knock, misfire, etc.)
4.74%
Yes, EVAP related (Gross leak, small leak, EVAP canister control valve, etc.)
29
11.46%
Yes, but something else.
2.37%
No.
141
55.73%
SES? That's my little yellow friend! He keeps me company at night.
18
7.11%
Multiple Choice Poll. Voters: 253. You may not vote on this poll
How many of you DON'T have an active check engine light?
Old Feb 27, 2011 | 12:32 PM
  #41
junglee Z's Avatar
Originally Posted by Scottwax
Getting an occasional pending P430 code and once a pending P1147 code. All started when I added a can of Seafoam to the gas last week. Must be cleaning out some nasty stuff in there. Hopefully once I burn through this tank and put some fresh gas in it, I'll be back to code free.
In my other Maxima (the one that got totaled), it had been code free for a good year and a half.
i did the same to my I35. i added seafoam to a full tank of gas and after that i've had constant misfire when the car is in D and stopped anywhere like a red light. i have to hold the brake and keep the rpm's at 1k or higher for it to not jurk and feel like it's dying.. haven't checked what code im getting yet.. hope you don't have the same problem!
Old Feb 27, 2011 | 01:44 PM
  #42
TunerMaxima3000's Avatar
Originally Posted by 2kmaxseblack2k
He keep's me company at night. haha...typically when its cold I have more problems with my ses light. I currently have one right now and have no idea, why or what it is. :_( any insight guys?
Maybe you should check it
Interesting, cause no-one has checked off the 'I have one but don't know what it is' on the poll....
Old Feb 27, 2011 | 06:26 PM
  #43
Eirik's Avatar
I only added it because I figured SURELY, somebody out there is n00b enough to not know how to check their code and get help fixing it.
Old Feb 28, 2011 | 05:34 AM
  #44
Clearly, but they obviously don't have the ***** to admit it.
00/01, not unlikely to have an undiagnosed light. I still haven't bought a code reader for mine, but I've used the neighbours.
Old Feb 28, 2011 | 07:21 AM
  #45
TheAnswer11's Avatar
Always had an 02 sensor on my 2000 but so far so good on my 5.5 Gen
Old Feb 28, 2011 | 07:24 AM
  #46
phatboislim's Avatar
if you dont have a SES light on in your maxima, your maxima is broke
Old Feb 28, 2011 | 07:41 AM
  #47
Sneaky Green's Avatar
lol true true
But after getting my car last September and having replaced clutch,flywheel,power steering pump and now the radiator. I have been giving it Shell plus gas, penzoil platinum oil ,bosch oil filter like clock work every 3k miles. I was throwing codes like I was a quarterback for a living. I let this last oil change run for 4500 miles around the 3000 mark I got no more codes. Gas mileage went up, and I idle smooth as ****. Gotta make up for lost time in our max's if they were used when you got em
Old Apr 6, 2011 | 10:32 AM
  #48
shaks's Avatar
Thanks for that tip (nohomo) but my battery/alternator are in good shape.
I assumed it was due to the broken Wheel sensor, and because its Auto, that throws the Trac and Slip light off too? Just made logical sense, I haven't bothered to fix the sensor yet.
that should be abs/speed sensor.
I've had the same issue and was thinking about buying new sensor.
After I checked under the car - a bolt broke down (have no idea how it happened). I screwed it out and put a new one in.
So, check front sensors and hope it to be something small...
Old Apr 6, 2011 | 06:43 PM
  #49
7speed's Avatar
No cel light ever
Old Apr 6, 2011 | 07:14 PM
  #50
Shift_A32B's Avatar
I had a P0136, turned out to be an o2 sensor...bought a new one (Bosch) and replaced the old one, CEL went out. CEL came back with the same ******* code like 1-2 months later....I am just going to ignore it...
Old Apr 6, 2011 | 07:57 PM
  #51
tombinator's Avatar
My CEL is on with 0420 and 0430 (cat codes) and has been since I bought my 01 I30 last year. Bought the car at 215XXX miles with the light on, and 21k later, it's still there. I get 24.5 average MPG in 70% highway/30% city driving, so I'm just not going to mess with "good enough". I figure I could spend the $500+ to replace the pre cats, all the O2 sensors, or just live with it. The car's registered in a state with no emissions/smog/safety test, so as my buddy Vinco (fellow .org member and friend) says... FIDO (you place the f) it, drive on.
By the way, the car runs smooth, and I have all the confidence it will run another 100k miles or more. Drive it 52 miles round trip to work every day and 700 miles each weekend, and never worry it will leave me stranded. Just went on a 1500 mile round trip and the car never missed a beat.
I'm convinced if you take care of the car, it will nearly last forever, regardless of the light being on... or not.
Old Apr 8, 2011 | 08:35 AM
  #52
hondaeatingtsi's Avatar
i dont have any at the moment.
the only code i have had in the last 6 yrs of ownership was for a throttle body. just out of power terrain coverage. but the service manager at the dealer i went to was good friends with my shop forman at lexus and got the repair covered.
Old Apr 8, 2011 | 10:14 AM
  #53
Eirik's Avatar
I don't see anything wrong, tombinator, with replacing the faulty cats to ensure it will run another 100,000 miles. Recall that the first ~150K miles were with new, shiny, not failing cats.
Old Apr 8, 2011 | 10:41 AM
  #54
Froggmann's Avatar
It's only shown up three times:
1st time: Didn't seal the gas cap properly.
2nd time: Didn't seal the gas cap properly.
3rd time: Forgot to plug in the MAF sensor.
Other than that 135,000 happy miles with my max.
Old Apr 8, 2011 | 11:14 AM
  #55
Shift_Max's Avatar
I do not have the ses light on my vehicle
Old Apr 8, 2011 | 09:40 PM
  #56
00Lightsout's Avatar
I've had my fair share of SES/CEL...fixed it every time, then cleared the code. I've never had a code repeated...KNOCK ON WOOOOOD!!!
Old Apr 8, 2011 | 10:46 PM
  #57
pinellas50's Avatar
I bought this car new. At 35K the CEL came on but the car still ran like a top. And it continues to do so to this day at 113K miles. The CEL has been on the entire time.
The code has always been P0420. I tried replacing the O2 sensor several years ago but the light stayed on. I just learned about the plug fouler thing and tried one of those but it is still on.
The CEL has been on so long that the wife and I don't even notice it anymore. And I don't see that changing anytime soon.
Old Apr 9, 2011 | 01:04 PM
  #58
fatboyslim86440's Avatar
84xxx miles with no cel and runs like straight shyt..
Rattles after reving around 3xxx rpm
Precat?
And feels like a damn brick getting on the high way...
maf?
Old Apr 9, 2011 | 02:31 PM
  #59
AltiMax2000's Avatar
After troubleshooting my ignition coils and replacing 2 of them, I've been CEL free for a year and a half.
Previous light was for the exhaust O2 sensor, once that was replaced and codes cleared with the OBDII reader, it never came back.
Old Jul 24, 2011 | 08:36 PM
  #60
tgorenc's Avatar
can you tell me what you did to fix the problem i have an 02 infiniti i35 basically the same thing......the same codes just popped up today and was wondering what you did to fix it and how long did clearing the codes work
thanks
tom g
Old Jul 24, 2011 | 08:38 PM
  #61
tgorenc's Avatar
Originally Posted by Ghost_54
Just once and awhile now P0455 & P1448 both related to the evap canister, I just reset them for now until I am ready to do the replacement parts
can you tell what you did to fix the problem
Old Jul 24, 2011 | 08:56 PM
  #62
colind94's Avatar
Oh yes, had a few codes over the years, always got them fixed, and have never had a re occuring problem except for my PITA evap problem-- code 1491. Anyone else had this problematic code? I just can't. get the damn thing fixed....
SHIFT__SES LIGHT
Old Jul 24, 2011 | 09:30 PM
  #63
T_Behr904's Avatar
2000 Maxima, P1320 primary ignition fault code. Prob the crank sensors, just haven't got around to changing them out yet. Runs great but there is a slight high rpm misfire at wot.
Old Jul 24, 2011 | 11:30 PM
  #64
yankeefan13's Avatar
No light on in mine currently...
Old Jul 24, 2011 | 11:58 PM
  #65
bgsl1ck's Avatar
I had a problem similair to this and it was the coil pack they told me it causes the car to miss so the tranny thinks it slipping change the coil pack all lights went away..
I am surprised with the resounding 'NO'.
I'm impressed with the poll results... so far.
Good thread OP.
Old Jul 25, 2011 | 07:25 AM
  #66
Thorzdad's Avatar
We've had an eternal CEL and the 0420 code practically since we drove the car off the lot new. It's never been a problem. Car has always run tip-top. We get it scanned every once in awhile, just to make sure some other code hasn't come-up, but it's always the 0420.
As I've explained in other posts (per discussions with Nissan techs), it's a nuisance light/code due to a software mismatch between what the computer expects to see and what the sensors are saying. Call it a false-positive. There's no actual problem and the engine will continue to perform as designed. You just get that eternal CEL. Sort of like there was a mis-communication between the mechanical engineers and the software engineers.
Old Jul 27, 2011 | 09:25 AM
  #67
Eirik's Avatar
I found your posts to be extremely informative, Thorzdad, when I was researching my '05's P0430--the same code as the P0420, just for the other bank.
But I don't think "miscommunication" between the hardware and software guys is quite accurate, more like the software guys got forced into the murky waters of politics and emissions regulations, and the result is that some cars end up with the wrong formula for determining whether or not the cat is functioning properly. I found it fascinating that Nissan can swap out those algorithms for CA vs Federal emissions cars... That got me thinking down entirely new lines about just what affect all this emissions stuff has on our cars.
Old Jul 27, 2011 | 07:16 PM
  #68
5150pa's Avatar
No Active CEL, I had the "Slow Response" code intermittently for a few weeks, but two cans of Techron (Magic?) and it's gone.
But no light doesn't mean everything is perfect, Timing chain guides must be whooped by the sounds it's making. Also sounds like Idler pulley (Maybe Harmonic balancer?) bearings are going/gone, that's also making a pretty sweet sound.
Old Jul 27, 2011 | 07:36 PM
  #69
KnightRyder8776's Avatar
I have the P0430 code
Old Jul 27, 2011 | 07:46 PM
  #70
killemall2k's Avatar
you are not alone..
Old Jul 28, 2011 | 12:02 AM
  #71
KBCobra's Avatar
211,000 miles. No CEL. Have never checked for codes.
Old Jul 28, 2011 | 06:53 PM
  #72
gdal's Avatar
I have had three CEL codes since I bought my Max last year.
1. Flashing CEL- one bad coil, but replaced all because they were the originals (only one with a dot)
2. (2) O2 sensors codes- Replaced a pre-cat sensor and after a week a post-cat sensor went out. I replaced all 4 units.
No CELs since the 02 sensor replacements ... knock on wood.
Old Jul 28, 2011 | 11:33 PM
  #73
MAXXED_816's Avatar
Just got my first one couple weeks ago, P0420
Old Jul 30, 2011 | 08:13 PM
  #74
leadfoot85's Avatar
My 2000 had a whole mess of codes (5 to be exact) about two weeks ago, but now it is only showing the awesome 0430. Going to get a sim one of these days...
But, the wife's 02 has been code free since we got it in March!
Old Aug 1, 2011 | 12:45 PM
  #75
Mikeb120's Avatar
I have a P430 still... had the TSB reprogram done a few times... it actually goes on and off... first thought it had to do with the gas as we just fill up with the nearest gas which could vary from shell to mobil. have not done the cat or o2 sensors... gas mileage is fine and considering it goes on and off its hard to admit there is an issue.
Old Aug 2, 2011 | 11:34 PM
  #76
DivaGal's Avatar
01 Max, No Light, but code
I think my light gave up on me. If you pull the codes you'll get one for O2 sensor, but the light hasn't come back on in a while now. She's probably due to remind me soon though
Old Aug 3, 2011 | 12:09 AM
  #77
BrooklynRussian's Avatar
No light for me......and it better stay that way lmao
Old Dec 7, 2011 | 10:11 AM
  #78
Bearmaster's Avatar
o2 Sensor
Old Dec 7, 2011 | 09:33 PM
  #79
Scottwax's Avatar
That's Mr. Detail to you
When I got an AM600 MAF out of a wrecking yard to replace the original one in my 6MT 6 speed to cure the infamous 6 speed hesitation issue (must have the AM600 for the ECU reflash to work), it greatly reduced the occurrence of the P0430 code I was getting regularly. Went from popping an SES light every 40-100 miles to every 300-600 miles. Not sure why but if you have the original MAF in your car, a new one might buy you enough time in between P0420/0430 SES lights to get your car to pass emissions testing.
Old Dec 8, 2011 | 06:23 AM
  #80
Rochester's Avatar
I should change my vote.
Been living with a failed secondary O2 sensor for almost two months. I have an O2 SIM installed, but the code is for the temp sensor, not the O2. So I clear it once a week just to make the light go away... but it's not I can pass inspection until I replace the damn thing.
