Chain replacements....
Old Mar 1, 2011 | 10:40 AM
aleem's Avatar
I am replacing the chains, guides, cam gears, tensioner, and water pump. Do you know of any places i can get it for "cheap"? Keep in mind it must be good quality lol
Old Mar 1, 2011 | 10:42 AM
aleem's Avatar
http://cgi.ebay.com/ebaymotors/95-01...#ht_1768wt_940
What you guys think?
Old Mar 1, 2011 | 10:47 AM
phatboislim's Avatar
cheap and good quality?! seriously?! and why are you replacing them anyway
Old Mar 1, 2011 | 11:15 AM
NmexMAX's Avatar
dot dot dot ...
Ok, so I'm assuming this is for an 00-01?
No reason to do cam gears or a water pump unless something is wrong. With the extent of this job, I would rather swap a used low mileage engine in tehre.
http://www.thepartsbin.com/ has "kits" to fit your needs.
Old Mar 1, 2011 | 11:45 AM
rosader's Avatar
When I did my timing chains (had a bad tensioner but decided to replace timing chains as well) I went ahead and replaced the water pump just because it's only about $80 and super easy to install when you already have the timing cover opened. I did have to replace a cam sprocket because I damaged it while I was taking it off but to the OP you more than likely won't need to replace any sprockets. I'm not sure about the VQ30 but I know the VQ35 intake sprocket cost an arm and a leg (over $300).
Old Mar 1, 2011 | 12:00 PM
NmexMAX's Avatar
dot dot dot ...
That's true actually, I did the opposite when I changed my water pump on my VQ30(changed tensioners & chains at the same time) So yeah, you're right.
Old Mar 1, 2011 | 12:42 PM
aleem's Avatar
my tensioner is bad and one of the guides broke and it jumped timing, chain has wear. pump is good. but im gonna change it any way cause im am not taking that **** apart again lol. taking the cover out was a pain in the ***... im looking for good quality but cheaper in price
gustavison
Oct 4, 2015 06:50 PM
kjlouis
Oct 3, 2015 05:29 AM
JoshG
51
Sep 21, 2015 10:41 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
