Cutting out when driving??
Old Mar 9, 2011 | 03:22 PM
slydel's Avatar
Please help.
Before I replace everything, any ideas of something obvious.
My 02 Max 6 speed just died the other day when driving, I engaged the clutch, the lights didn't come on so I suspect the engine was running.
The clock is correct, so no battery issue.
After about 1/2 mile of coast, on, coast the engine started running fine.
There was no popping or puffing like a fuel starvation issue, no over heating, no engine light.
200k miles. I am suspecting a throttle position sensor or the like???
Old Mar 9, 2011 | 04:11 PM
Grand_hustle17's Avatar
samething use to happen to mines when i first bought it... some how it stopped, codes read from advance auto read TPS, but i believe the spacific problem was accelerator pedal position sensor (APPS) might be the same... any codes??
edit... u said no engine light so nvmd
Old Mar 9, 2011 | 04:14 PM
Maybe a cam/crank pos. sensor is on the way out.
Old Mar 9, 2011 | 05:24 PM
slydel's Avatar
No codes
Old Mar 9, 2011 | 05:27 PM
Scottwax's Avatar
That's Mr. Detail to you
I'd look at the camshaft/crankshaft position sensors first. Just because you don't have an SES light doesn't mean you don't have any stored pending codes.
Old Mar 9, 2011 | 05:45 PM
lake985's Avatar
+1 on the cam/crankshaft sensors. I had the same problem of the engine intermittently cutting out. At first there was no SES light, but you'll probably get one eventually.
Old Mar 9, 2011 | 08:34 PM
CMax03's Avatar
+2^^^
Old Mar 10, 2011 | 01:02 PM
Same thing happened to me. Once the SES light came on I got the code and it ended up being the rear (bank one) camshaft position sensor. I swapped it out and everything was back to normal.
Old Mar 28, 2011 | 10:21 AM
cremster's Avatar
Just bought my 2k2 Maxima SE with 96k...when the car turned off on me on a red light on the second day of driving..I started to think..this private seller got over on me..it started back up and rerouted to Autozone to realize that the Camshaft/Crank Sensor codes came up....I hit the internet and found out that these 2002 Maximas had a few recalls...didnt hurt to call Nissan North America with my VIN#...and BAM!!Three open recalls...Accelerator Pedal....Transverse Link....and drumroll please....Crankshaft Sensor!!! I made an appointment for tomorrow at Star Nissan in Queens to repair these at NO CHARGE!!..I will however have to shell out for 2 Camshaft Sensors...their price are $96.00 for one, $70.00 for the other...dont know if these Camshaft Sensors are an easy fix or should I let the dealership guys come up with an astrological number for labor cost??
Old Mar 28, 2011 | 05:13 PM
Scottwax's Avatar
Buy the camshaft sensors yourself, pretty easy to install. Great access to bank 2 (radiator side), airbox has to come out to access the bank 1 sensor. 1 electrical clip and 1 bolt to remove for the sensors themselves.
Old Mar 28, 2011 | 07:12 PM
cremster's Avatar
Thanx a lot Scottwax...I guess its a DYI all the way!!
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
Maxie40
Sep 14, 2015 11:28 AM
Maxima30
Sep 7, 2015 06:13 PM
