question is this normal
Old Mar 9, 2011 | 11:56 PM
mrjamaica98mx's Avatar
car was shaking at a stop light so i pulled over pop the hood and i noticed this my ? is this normal? pipe is sweating pic below
Old Mar 9, 2011 | 11:58 PM
MAXXED_816's Avatar
sweating?
Old Mar 10, 2011 | 12:01 AM
do u see like the water drops on the pipe look closely
Old Mar 10, 2011 | 04:18 AM
SteveB123's Avatar
Cold A/C line in hot weather.
Condensation.
Old Mar 10, 2011 | 04:39 AM
MadMax07SL's Avatar
Sweating AC lines are completely normal. Why do you think they put insulation around them in homes and businesses? Sure part of it is to make the pipe more efficient, the other reason is to prevent moisture buildup and dripping or mold to set in...Ever been to a place that had a leak in the false ceiling? Probably an exposed AC line drawing in moisture and dripping down into the ceiling...
Old Mar 10, 2011 | 04:58 AM
kukx30de's Avatar
Perfectly normal.
Old Mar 10, 2011 | 06:26 AM
Eirik's Avatar
Funniest thread I've read today.
Old Mar 10, 2011 | 07:42 AM
MadMax07SL's Avatar
Naa, the guy that ran his car 20k+ miles without an oil change is the funniest...
Old Mar 10, 2011 | 07:53 AM
Mr. Ryte's Avatar
Go easy on him fellas. He may not be as car savvy as the rest of us. I did the same thing myself at one point.
We were ALL noobz at one point.
As for the person that went 20k+ miles without an oil change......
Old Mar 10, 2011 | 11:50 AM
thanks for replies
Old Mar 12, 2011 | 11:21 PM
lalaMAX's Avatar
btw, do you have the weird noise after you replace your pressure hose? I have the same PS pressure hose as yours, but I get this kinda weird noise sounds like I am low on PS fluid
Old Mar 13, 2011 | 08:16 AM
Rods03Max619's Avatar
When you get your license you should know the basics and that is the big one every 3000 miles change you oil hell even commericals tell you that....And on the Topic...Normal..
Old Mar 13, 2011 | 02:55 PM
SteveB123's Avatar
Congratulations.
You've confused knowledge with marketing.
Old Mar 13, 2011 | 03:08 PM
Yes i do gonna change pump this wknd
Old Mar 13, 2011 | 03:14 PM
Old Mar 14, 2011 | 04:47 AM
lalaMAX's Avatar
Let me know if it fixes the sound issue. Keep in mind that my pump wasnt making any noise b4 the hose change.
Old Mar 14, 2011 | 10:17 AM
My mechanoc says because i drove w leaking hose pump weny bad .
Old Mar 19, 2011 | 04:11 AM
lalaMAX's Avatar
so anymore noise after PS pump replacement? I need to make sure if the noise is coming from the hose or pump it self.
I did a little search, looks like most people who replaced pressure hose will for sure get that noise, so it might be the hose's problem.
Old Mar 19, 2011 | 12:00 PM
seller send me a refund saying he broke it while removing it so stuck with noise no else selling the part so i may go to napa debating.............
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
AT978
Sep 6, 2015 10:31 PM
Johnny9595
Sep 3, 2015 05:18 AM
