Just curious to know how many has had to replace radiator after 105k etc
Old Feb 26, 2011 | 02:30 PM
MONTE 01&97 SE's Avatar
After reading a few threads on radiators, I'm just curious to know how many have had to and how many have not had to replace their radiator after say 105k miles or so. Thanks
Old Feb 26, 2011 | 02:58 PM
RLW001's Avatar
In PA where I live the temp extremes shorten radiator life. My rad was starting to "weep" a bit and did not want to risk get stranded.
Old Feb 26, 2011 | 04:57 PM
Scottwax's Avatar
That's Mr. Detail to you
Replaced the radiator in my 4AT 5.5 gen at around the 130k mark if I remember right. One of the Maximas I looked at to replace mine also had the radiator replaced at around the same mileage.
Metal tank, plastic ends, eventually they leak.
Old Feb 26, 2011 | 06:22 PM
nelledge's Avatar
"I'm just sayin'..."
Replaced mine around 120k. Hair line crack in plastic tank at a stress riser. The failure is not biased to Maximas or Nissans. Happens to all plastic tanks sooner or later. Cheap and easy part to replace. No complaints here.
Old Feb 26, 2011 | 07:52 PM
Rods03Max619's Avatar
Haven't had to replace mine yet at 151,000 miles.....
Old Feb 26, 2011 | 07:59 PM
nismopc's Avatar
Same here! Just hit 160k
Old Feb 26, 2011 | 08:05 PM
Sneaky Green's Avatar
Mine blew at 100k exactly lol. Is there a d.i.y on it with the koyo replacement?
Old Feb 26, 2011 | 08:10 PM
Ghost_54's Avatar
Mine was just starting to weep across the top seem at 208,000km and was recently replaced when I had my front end accident back in late December at 214,000km
Old Feb 26, 2011 | 08:14 PM
mrjamaica98mx's Avatar
replaced
Old Feb 26, 2011 | 08:23 PM
The6spdMax's Avatar
Leak around 105k. Common leak on the top.. Replaced with koyo with Toyota red. Easy replacement.
Old Feb 26, 2011 | 08:26 PM
MizzMaxine's Avatar
I've changed mine.
Old Feb 26, 2011 | 10:48 PM
Thanks fellas, I was just curious to know as I have not had to replace mine yet at 115k.
Old Feb 26, 2011 | 11:04 PM
kbohip's Avatar
108,000 on original radiator and it not a leak or split anywhere....so far.
Old Feb 27, 2011 | 07:13 AM
BigMarcus's Avatar
Wow . . . I am starting to think something went terribly wrong because I just had to replace my radiator at 77,000
Old Feb 27, 2011 | 08:03 AM
Thorzdad's Avatar
We didn't have to replace ours until around 300k.
Old Feb 27, 2011 | 08:51 AM
Shift_A32B's Avatar
203000 miles, and haven't replaced my radiator.
Old Feb 27, 2011 | 08:57 AM
zoner's Avatar
Wow, really? You guys flushing the cooling system and replacing the coolant per the recommended intervals? 186K and still on the original radiator.
Old Feb 27, 2011 | 09:08 AM
Thorzdad's Avatar
Nope. Nothing special. I'm sure the coolant was changed at some point or another, but I can't honestly say when.
Old Feb 27, 2011 | 11:40 AM
cabernet's Avatar
Mine lasted 153,000 miles and then sprung a huge leak.
Old Feb 27, 2011 | 12:23 PM
J-Rod's Avatar
Just did mines, 128,000 and had a hair line crack in front of it to left of cap.
Old Feb 27, 2011 | 02:54 PM
al_maxima's Avatar
Mines still stock (118k) but i had a huge crack right underneath the intake, which i fixed with JB weld.
Old Feb 28, 2011 | 08:48 AM
nissandrvr98's Avatar
mine went at the beginning of jan this year w/136k on the clock. cracked around the plastic cap on the core. made a mess of the engine bay too.
pretty simple swap out, just time consuming (took me about 2 1/2 hrs and a half case of miller
Old Feb 28, 2011 | 08:58 AM
nelledge's Avatar
Originally Posted by nissandrvr98
...pretty simple swap out, just time consuming (took me about 2 1/2 hrs and a half case of miller
Probably could've been done in half an hour without the Miller.
Old Feb 28, 2011 | 09:21 AM
tookrzy4u192's Avatar
Mine went out at 82k or so..
Old Feb 28, 2011 | 01:10 PM
lake985's Avatar
had mine replaced at 106k
Old Mar 1, 2011 | 05:45 AM
Mizike's Avatar
My radiator lasted around 160,000ish miles. I felt I got my moneys worth out of the stock radiator.
Old Mar 1, 2011 | 06:12 AM
damerbullet's Avatar
More than 130,000 miles and still going strong
Old Mar 1, 2011 | 06:29 AM
jtm02011's Avatar
194K and no leaks.
Old Mar 1, 2011 | 08:09 AM
nismonegro26's Avatar
I had to replace mine at 69k
Old Mar 1, 2011 | 01:15 PM
gtmustang89's Avatar
129,000mi and still no leaks
Old Mar 1, 2011 | 01:57 PM
llgonzales's Avatar
replaced mine two weeks ago at 184,000, started weeping at the seam. I had zero experience working on cars and did it in about two hours.
Old Mar 18, 2011 | 01:07 PM
BlueOrder's Avatar
Started leaking and replaced at around 140k
Old Mar 18, 2011 | 03:15 PM
rogue08's Avatar
I feel better after reviewing these posts. My 2001 AE's radiator just started leaking at the top with 127,500.
Old Mar 19, 2011 | 04:51 AM
TheOnlyMax88's Avatar
yup mine just went sprayed everywhere, around 126K seeping out where nissan puts there stamp on top right
Old Mar 19, 2011 | 06:08 AM
Boost_boy's Avatar
My 5th Gen GLE popped it's top @ or around 80k. Changed it and now the car just went over 100k, so let's see how long it lasts from this point.
Old Mar 19, 2011 | 12:54 PM
DennisMik's Avatar
My 2000 with 87K has started to leak. Just received a new Koyo a couple of days ago and hope to be able to put it in within the next week or so. Strangely, almost exactly 2 years ago, I had to replace the radiator on my 97.
CRizz
41
Jun 7, 2021 05:42 AM
mvm062
Nov 30, 2020 09:00 AM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 6, 2015 11:36 AM
