NWP VIAS Plate and Oil Discovery
Old Mar 13, 2011 | 03:48 PM
ilacuss's Avatar
So after the recent thread on the mostly rave reviews of the NWP VIAS Plate, I decided to install one. When installing I found an oil puddle in the air chamber-not sure exactly what it's called. Car has 145k on it and I just picked it up about a month ago. It does use some oil, not sure how much as I haven't put many miles on it yet. Does this mean I needs a new valve cover gasket? I read the 04 gasket works better. Thanks for any input. Name:  oqXwG.jpg
Old Mar 13, 2011 | 04:11 PM
Gizm0's Avatar
Unfortunately a new rear VC may not even fix your problem. See this thread:
http://forums.maxima.org/5th-generat...nsumption.html
Old Mar 13, 2011 | 04:30 PM
Mr. Brett's Avatar
Oil in the manifold like that is usually an indication that your PCV valves are stopped up, or getting there. I'd try cleaning out your PCV valves first, and if the puddling issue doesn't clear up, it may be something more serious.
Remember that there will always be SOME oil in the manifold because the engine has lines that collect the blow-by and suck it into the engine to be burned up (that's what the PCV valves are there for). But if you have a serious puddle in the IM, then you might want to start out with your valve covers.
Old Mar 13, 2011 | 06:12 PM
Scottwax's Avatar
That's Mr. Detail to you
My 4AT 5.5 gen was using a quart of oil every 1500'ish miles and I didn't have nearly that much oil in my intake when I put the block plate on. I had put a new PCV on it the year before, maybe that helped.
Old Mar 14, 2011 | 09:40 AM
ilacuss's Avatar
Replaced the PCV valve today, it was caked in oil and looked clogged. Thanks for the tip Scott. We'll see if that fixes the issue. Should I clean the plenum or just leave as is?
On a side note, I love the smooth accelerating that the VIAS delete provides. Didn't feel a loss of power and seems to accelerate without jerkyness.
Old Mar 14, 2011 | 09:43 AM
Rochester's Avatar
You keep saying that, like there's more than one.
Old Mar 14, 2011 | 04:53 PM
crazy97's Avatar
You can change the pcv valve and valve covers till you are blue in the face, you will never stop the oil from getting in there. Unless this works...
link ---> http://forums.maxima.org/5th-generat...nsumption.html
Old Mar 14, 2011 | 05:07 PM
Scottwax's Avatar
I'd wipe it out with a microfiber cloth you never intend to use again.
I agree on the smoothness, power delivery is more linear even though I did notice some minor loss of power from 2800-3800 at times, like when I'd hit the gas and whatever gear it dropped to put me in the 2800-3800 rpm range.
I think some of the improvement in smoothness has to do with the fact our cars are at least 8 years old now and the vacuum lines are starting to deteriorate and cannisters aren't holding vacuum as well as when new.
Old Mar 14, 2011 | 05:12 PM
Rochester's Avatar
What? No. The "improvement" is because you lose low-end torque and gain high-end HP, so the transition is more noticeable. Ergo, butt-dyno happiness.
Old Mar 14, 2011 | 05:40 PM
Scottwax's Avatar
I meant in smoothness, not power, thought that was pretty clear.
Old Mar 14, 2011 | 06:32 PM
Rochester's Avatar
My bad. Reading > me, sometimes. Smoothness... yes indeed. The VIAS-delete is a much more smooth experience than having the valve open up and kicking in. I much prefer the way the car performs without the VIAS.
Old Mar 31, 2011 | 10:35 PM
altezzablazes's Avatar
place an oil catch can inline on your pcv line. and just dump the can when full
Old Apr 1, 2011 | 07:27 AM
ilacuss's Avatar
I replaced the PCV valve and that seemed to help. I need to check it again, but I'll wait on doing that until I do the plugs next week.
Old Jul 11, 2011 | 11:18 PM
NismoAltimaGuy's Avatar
Yeah... do that... the Oil catch can works well if installed correctly.
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
