Oil In Ignition Coil?
Old Mar 15, 2011 | 06:51 AM
chsherbie's Avatar
Hey guys long time,
I just changed my spark plugs after 100k Miles because my gas mileage is down to about 18 on the highway. I changed the front 3 plugs fine and took the intake plenum off and then changed the rear 3 plugs.
When I removed the final ignition coil (closest to the driver) and I took it out the region that it sticks into it was filled with oil. I am losing a couple quarts between oil changes. Is my problem a leaky valve cover gasket that was letting oil leak into that ignition coil chamber?
Old Mar 15, 2011 | 06:54 AM
NmexMAX's Avatar
dot dot dot ...
You problem is most likely a cracked VC. Common. Search and see just how common it is.
Old Mar 15, 2011 | 08:27 AM
Ghost_54's Avatar
Yup seems to be pretty common that #5 cylinder has oil in the chamber, time to upgrade that rear VC to the 04 version little better design than the 03 version and you will find it costs less to upgrade to the 04 version.
Old Mar 15, 2011 | 08:32 AM
chsherbie's Avatar
where can I find the 04 valve covers for sale? And should I change the PCV valve?
Old Mar 15, 2011 | 08:37 AM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/5th-generat...kes-again.html
http://forums.maxima.org/5th-generat...ement-how.html
http://forums.maxima.org/4th-generat...ht=valve+cover
http://forums.maxima.org/5th-generat...ark-plugs.html
jmlee44
Oct 2, 2022 02:13 PM
mclasser
22
Nov 12, 2020 01:58 PM
AaronL
Aug 8, 2020 10:31 AM
05RLS2
Apr 14, 2016 11:49 AM
zmcneely13
Sep 26, 2015 02:26 PM
