Coolant leak - Can not find the actual leak !
Old Apr 8, 2011 | 12:03 PM
Saadkhan07's Avatar
Ok guys,
I opened my hood up to check the oil one day, and found this :
Uploaded with ImageShack.us
Obviously this is a coolant leak, as i see fresh AF on the hoses...I ran the car, got it hot after driving it, yet i dont see a active leak anywhere. Im confused if its the hoses or the rad itself. Has anyone also experienced this issue ?
Thank You.
Old Apr 8, 2011 | 03:53 PM
T.One's Avatar
CONTEST!
No its probably your seals that goes around your actual radiator plastic top. Thats what was wrong with mine
Old Apr 8, 2011 | 04:08 PM
Ghost_54's Avatar
Yup, that is where the leak first appears ... right where the rad support brackets are ... check along the crimp edge at the plastic it over time develops small cracks and when under high pressure you get that lovely spray off ... time for a rad replacement.
Koyo is the best replacement
http://forums.maxima.org/group-deals...t-pricing.html
Old Apr 8, 2011 | 05:30 PM
T.One's Avatar
I agree with the Koyo, but get it from importrp and support .org people and get an extra 10% off jus for being on the org with free shipping too
Old Apr 9, 2011 | 11:13 AM
trooplewis's Avatar
$64 OEM replacement on ebay (including shipping) and good for another 10 years.
Old Apr 9, 2011 | 11:54 AM
DennisMik's Avatar
I've had to replace 3 radiators and all of them started to leak beneath the upper radiator hose area.
Old Apr 9, 2011 | 04:53 PM
T.One's Avatar
Go get a 4th gen ome though. Theyrr twice as big and fit
Old Apr 9, 2011 | 06:08 PM
compton2k11's Avatar
I replaced mine last month.. On the top of the rad you can see where it was seeping and causing it to spray everywhere..
Old Apr 10, 2011 | 11:05 AM
scarface4522's Avatar
same problem here, ima go with the spectra premium radiator from rockauto. radiator+upper and lower hose for about 107 shipped
Old Apr 10, 2011 | 11:24 AM
that's exactly what I did.
Old Apr 10, 2011 | 05:18 PM
TunerMaxima3000's Avatar
Cause bigger is better?
Good to know that it fits though!
Old Apr 10, 2011 | 11:36 PM
Saadkhan07's Avatar
re
Thanks guys...you guys are right..its at the top left crimp edge...i can tell its all due to pressure.
ill see what comes up the best. I can get it for $80 through 1800 radiator. Replaced one on my accord before, and it was a great OEM rad. This sucks !!
got cams going out and now this too... !!!1
Old Apr 11, 2011 | 06:34 AM
CMax03's Avatar
1800RADIATOR will drop ship it to your front in less than 24 hrs! They have several brands I went with KOYO......
Old Apr 19, 2011 | 07:17 PM
DanMaxima's Avatar
Hum, I wonder if this is the same issue I'm having.
Engine residue -- white and chalky
Old Apr 19, 2011 | 08:11 PM
^Likely
Old Apr 20, 2011 | 12:56 PM
DanMaxima's Avatar
^Likely
When I was changing my oil after a quick (10-15min) drive, I noticed my engine seem rather hot, and it looked like the coolant reservoir was empty (though the lighting is rather poor in my garage so it was hard to tell).
I put coolant into the reservoir about halfway between the Max and Min marks, took the car out for lunch today, and when I got back the coolant reservoir (with additional lighting, via a drop light, this time) appeared to be bone dry. So the coolant is going somewhere, though there didn't seem to be any additional residue in the engine bay.
That's a fair amount of coolant, so perhaps it's leaking elsewhere, and what's in the engine bay is due to salt on the road.
I filled the coolant reservoir up again to about halfway between the Max and Min marks, and cleaning the engine bay so any future spraying will be readily noticeable, but I have a hunch I'm going to do some additional diagnosing.
OP, sorry about the hijack.
Old Apr 20, 2011 | 09:00 PM
DanMaxima's Avatar
Like this?
Old Apr 28, 2011 | 03:51 PM
BobPezz's Avatar
Originally Posted by DanMaxima
Like this?
That's where mine is leaking too, right after a cooling system (pressure) flush.
I know everyone here recommends Koyo Radiators. But they're a plastic tank/aluminum core construction. Which I've had problems with in the past (leaking at the core/tank junction). Has anyone tried/used the ALL metal (tank/core) CSF brand radiator? Please give opinions or experiences.
Thanx in advance!
Justinmc760
Aug 23, 2015 03:10 AM
FlaMark
Aug 21, 2015 11:06 AM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
