How To Tap Into Fuel Pump..?
Old Apr 9, 2011 | 03:24 PM
MizzMaxine's Avatar
Where is the fuel pump line underneath the drivers dash?
Old Apr 9, 2011 | 05:27 PM
DennisMik's Avatar
When you say under the dash, are you referring to the electrical circuit or the liquid stuff? The liquid gasoline is not routed under the dash, the tube/pipe it runs through is on the underside of the floor on the driver's side.
Old Apr 9, 2011 | 05:29 PM
MizzMaxine's Avatar
Its the electrical circuit I'm looking for. Any idea?
Old Apr 10, 2011 | 10:03 AM
DennisMik's Avatar
The ECU tells the fuel pump to run. It energizes a relay (which Nissan for some reason calls the Fuel Pump Relay) and the relay sends 12 volts to the fuel pump. Fuse # 29 (15 amps) protects the circuit. The wire that goes to the fuel pump is on pin 3 of the relay, a black/yellow stripe (on a 2001 model anyway).
The fuel pump relay is located behind the driver's side kick panel (ahead of the door & below the dash. There are 2 relays there, the fuel pump relay is closer to the door. FWIW, the other one is the rear window defogger relay.
The electrical diagram is on page EC-620 and the relay location is on pages EL-354 & 355, again this is for the 2001 model. Other year models may be different, usually only a page or 2.
You can download a manual from:
http://www.nicoclub.com/FSM/maxima/
The file named fwd.pdf is the chapter index file for the rest.
The file named idx.pdf is the alphabetical index file for the rest.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Forge277
Jun 13, 2016 09:26 PM
