Fighting Vibration
Old Apr 9, 2011 | 04:32 PM
Grand_hustle17's Avatar
Fighting Vibration
So here is the current issue, ever since getting the car back ive had a very, and i mean very bad vibration issue... the 1st suspect was the GSP axles and their known issues with 6spd transmissions.. i got it changed today for an OEM axle and it did somewhat helped the vibration however its still a pretty bad vibration, its noticeable and uncomfortable at certain speeds but its more noticeable when making right turns, it completely goes away when making a left turn... im using the auto axle for the left side and from what i remember its the samething, correct me if im wrong... anyways, for anybody that have battled vibration issues any help or advice will do thank you
Old Apr 9, 2011 | 06:02 PM
mahanddeem's Avatar
what about the engine and transmition mounts ?
Old Apr 9, 2011 | 08:30 PM
Mmmm, I'm thinking the same.... trans mount
Old Apr 10, 2011 | 12:52 AM
00Lightsout's Avatar
could be either of you lateral moving motor mounts, the one side of the axles that you have not just recently replaced. You are dropped A LOT :/ ...too much for long lasting suspension geometry. start with checking the lateral mounts and inner and outer tie rods, if good replace the other axle.
Old Apr 10, 2011 | 01:04 AM
Nexus67's Avatar
Have to agree on the inner/outer tie rods (especially considering a pronounced increase in vibration on right turns)
Old Apr 10, 2011 | 05:51 AM
OHH NOES's Avatar
6spd Swapped
It increases on the right turn because the pass side axle becomes stretched and decreases on a left turn because the axle collapses. It's definitely an axle, pass side 6spd axles are notorious for going bad even immediately after install. Make sure you have a 6spd axle and not an auto axle, I know your new to 6spds so I don't know if your familiar with how hard it is to find 6spd axles and how a lot of stores think theyre the same and sell autos as 6spd. The driver side auto and 6spd are the same. Try to get a new axles and raise the car as much as possible to test this out. A few other possibilities are ball joints, mounts, tie rods.
Old Apr 10, 2011 | 05:58 AM
I thought it was the passenger side axles but I ordered a passenger side axle from car-parts from a 6spd maxima
Old Apr 10, 2011 | 06:03 AM
Just a quick info... the car seen in my sig is my previous DEK which is totalled... the car I have now is nowhere close to being as low as this car, the drop on my 5.5 is where the top of the wheel weld sits on the top of the tire no tucking
Old Apr 10, 2011 | 08:20 AM
CMax03's Avatar
How about jacking that bish up and pulling out the pry bar and checking your engine mounts and driveshafts for (full engagement into the differential) I would put it on stands and put it in drive and look for an obvious problem.....first and foremost!
Old Apr 10, 2011 | 12:37 PM
so our drops are about the same
just to be sure check, check, and recheck before you drop $$$ into fixing it.
Old Apr 11, 2011 | 09:06 AM
OHH NOES's Avatar
6spd Swapped
That's still too low for these ****ty axles, if you want the vibration gone you'll need finger gaps.
Old Apr 11, 2011 | 09:18 AM
I get the vibration with that kind of drop but it was the same ride height with the auto and I probebly got no vibration... I can tolerate alil vibration, not vibration that cause the steering wheel to turn at about 3-5*'s left n right shoot it might be 10*'s fo real
Old Apr 11, 2011 | 09:35 AM
kukx30de's Avatar
If you have left right steering vibration... my vote goes to the inner or outer tie rods or the LCA bushings/ball joints.
If it was CV axles.. it would be a cyclic vibration which is not characterized by left right vibration in the steering rather it feels like a front back vibration.
Old Apr 11, 2011 | 10:18 AM
Eirik's Avatar
Ohhhhhhhhhhhhhhhhhhh... This makes your posts much, much less confusing to me now. I didn't realize you were in a VQ35 now. Congrats.
Old Apr 11, 2011 | 05:00 PM
OHH NOES's Avatar
6spd Swapped
6spd axles are longer, they take less of a beating and can't take as much of a drop. I went from auto to 6spd too..
Old Apr 11, 2011 | 06:12 PM
didnt you have clutch problems for a bit?
Old Apr 11, 2011 | 07:26 PM
OHH NOES's Avatar
6spd Swapped
After the turbo, clutch couldn't handle the extra power.
Old Apr 11, 2011 | 08:02 PM
foodmanry's Avatar
Da Roller Coaster!
Old Apr 12, 2011 | 04:31 AM
Idk if this is sarcasm but thanks I guess... this is going on 3yrs since I've owned a 5.5 bro
Old Jun 17, 2011 | 08:31 AM
mattbaga's Avatar
left right steering wheel movement = tierods or ball joints...up and down movement = wheel balance or bearing
Old Jun 17, 2011 | 10:26 AM
NmexMAX's Avatar
dot dot dot ...
How many months ago was this?
user 11122324
42
Jul 18, 2022 03:35 PM
HOKUSMAX
Nov 13, 2017 04:34 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
06maxima55
Sep 28, 2015 04:29 PM
Bonka
Sep 14, 2015 11:18 PM
