Drop-in LED instrument cluster lighting for 5.5 owners. Finally found one that works!
Old Jun 14, 2011 | 08:01 PM
  #441
Rods03Max619's Avatar
Originally Posted by nelledge
T10 instead of T5? Easy mistake to make. Sucks.
Looked on the site for the T5 dont see them anybody got a part number....took out the whole thing and to see I couldnt take out the damn Bulb from the socket ....so need those T5's....
Old Jun 14, 2011 | 08:47 PM
  #442
nelledge's Avatar
"I'm just sayin'..."
Post #267:
Originally Posted by Polished2002
Old Jun 14, 2011 | 09:58 PM
  #443
Post #267:
Thanks...says not avaliable right now, checked ebay and ordered from there but coming from Hong Kong.....
Old Jun 14, 2011 | 10:41 PM
  #444
nelledge's Avatar
Thanks...says not avaliable right now, I'll check another day.....
Yeah, they're tough little guys to find. Here are a couple other links I've found. Link 1 and Link 2. I can't attest to the companies, but I thought I'd throw out some kind of results.
Old Jun 15, 2011 | 07:10 AM
  #445
Polished2002's Avatar
T5 Replacements from Hong Kong
I purchased 5 of the T-5 wedge bases (from Hong Kong via Amazon) and FYI, the quality is NOT the same as OEM. The bulbs/LEDs fit fine, but you have to apply a different method to getting the wedge bases installed in your cluster.
With the OEM, you push it in until you are forced to stop, then easily turn to lock in place. Using the replacements, I had to push in and let it fall down a bit while I kept trying to turn to lock it in place. Finally you will reach the point where it may turn and you have to apply a bit more force. Lets just say that some of the plastic started shearing off.
I spent about half an hour trying to install these like I would the OEM, then realized they don't lock into position the same way.
Old Jun 15, 2011 | 04:46 PM
  #446
Thanks for those, is there a certain way to turn the socket cause my lights are not working in the Speedo with the stock lights...
Old Jun 15, 2011 | 05:09 PM
  #447
laxmax's Avatar
I tried green and it looks way good! you couldn't tell that the blue tint was there. i dunno about other colors though.
Old Jun 15, 2011 | 07:51 PM
  #448
SeedyROM's Avatar
Got any pics by chance? And was it the same bulbs (superbrightleds.com) as my original post just in green or some others?
Old Jun 16, 2011 | 07:28 AM
  #449
NmexMAX's Avatar
dot dot dot ...
The items I ordered from D&M auto was way too expensive and they're too big, I assume incorrect PN.
Old Jun 25, 2011 | 06:04 PM
  #450
SeedyROM's Avatar
Originally Posted by tomcat
I'm gonna go with warm white.
Thread back from the dead Post up your results when you can.
Old Jun 28, 2011 | 09:19 AM
  #451
SupaFly's Avatar
Warm White LEDs
I'm glad I went with these.
Attached Thumbnails Drop-in LED instrument cluster lighting for 5.5 owners. Finally found one that works!-photo1.jpg   Drop-in LED instrument cluster lighting for 5.5 owners. Finally found one that works!-photo2.jpg
Old Jun 28, 2011 | 09:53 AM
  #452
Rochester's Avatar
That's an OEM color, just brighter. I was expecting to like that config, too. Surprised that I didn't. Toe-may-toe, toe-mah-toe.
Man, you've got some low miles on that car, SupaFly. And here I thought my miles were light.
Old Jun 28, 2011 | 10:05 AM
  #453
SupaFly's Avatar
I don't remember the OEM color ever being "white", but it's been 9 years since they were new.
I took public transportation to work for the first 5 years having the car
Old Jun 28, 2011 | 12:16 PM
  #454
nismopc's Avatar
They never were. Always a yellowish dim color. Over time, just got more dim.
I have same set-up 'warm white' and love it. Perfect amount of light at night.
Old Jun 28, 2011 | 07:05 PM
  #455
TunerMaxima3000's Avatar
Has anyone tried a colour yet??
Old Jun 29, 2011 | 08:06 PM
  #456
Just busted a 2nd attempt with the t5 from Hong Kong they do not work and arent the same size as OEM damn it..off ebay..now got to check Amazon and see if they have them in stock....
Old Jun 29, 2011 | 10:44 PM
  #457
omi239's Avatar
I tried doing that with a single blue #74 led and i just had two major hotspots, glad you finally figured it out for us. i will be attempting this soon. Thanks man
Old Jun 29, 2011 | 11:26 PM
  #458
SeedyROM's Avatar
My pleasure! I'm sure you'll love it.
Old Jun 30, 2011 | 05:30 AM
  #459
bred's Avatar
thought I'd share my luck using the pink film over the clock, thanks to Rochester who hooked me up
Old Jun 30, 2011 | 05:44 AM
  #460
nelledge's Avatar
Looks good! Same results(different time however) from the same gifting.
Old Jun 30, 2011 | 05:53 AM
  #461
Rochester's Avatar
I'd like to do the same with my radio, but the desire can't seem to overcome the laziness.
Maybe when I see Tunermax in a few weeks, he'll give me some inspiration on how to do that.
Old Jun 30, 2011 | 06:15 PM
  #462
Ha, you want me to help you overcome the laziness? I still haven't put the strip you sent me in
Looks great though, and the quality of it is amazing, much better than the cheap film I used before. Be sure to bring that stuff with you when you come, we'll put it in the ACC while you're here.
Old Jul 1, 2011 | 04:40 AM
  #463
Rochester's Avatar
Good idea. Will do.
Old Jul 1, 2011 | 08:09 AM
  #464
UGAd13's Avatar
Me likes... need to do mine.
Same here. What film did you go with again? I don't want to search through all the pages...
Old Jul 1, 2011 | 08:15 AM
  #465
Rochester's Avatar
Freaking lazy-azz. Here:
Old Jul 1, 2011 | 10:45 AM
  #466
nismopc's Avatar
Well, I decided the Radio Shack mod I did to my HVAC was too bright for my tastes and did not flow well with the warm white dash LEDs (74-WWHP3) or my stereo, so I ordered some red NEO4-R LED's and swapped out my DIY LEDs. Also replaced courtesy bulb under HVAC with a 74-WWHP3 to flow with dash.
Much more pleased with results...
BEFORE: Radio Shack LED mod...
AFTER: RED NEO4-R replacements... (crappy cellphone)
Old Jul 1, 2011 | 07:09 PM
  #467
^ Wow that turned out quite well, red is one of the 'darkest' colours you can use, and it still looks quite vibrant. The 'courtesy light' (is that what we've decided to call it? I'm never sure) is super bright, those little bulbs never cease to amaze me
Old Jul 1, 2011 | 07:45 PM
  #468
nismopc's Avatar
I'm just happy that the red's are the same exact color and brightness between the HVAC and the Sony. I almost went with the HP NEO's which are 6 lumens vs. these which are only 2 lumens. Glad I didn't...
Old Jul 2, 2011 | 08:41 AM
  #469
Still waiting on this, colour testing is a much needed part of this thread.
Old Jul 5, 2011 | 09:41 PM
  #470
michael454rs's Avatar
whent on the super bright led website to try an order the warm white led's, but i cant seem to find them im looking for the warm white i think it's the 74-WWHP3, if anyone can help can even seem the the correct page to add them to the cart lol
Old Jul 5, 2011 | 09:52 PM
  #471
SeedyROM's Avatar
That's correct. On the page it should say "Warm White" right next to the 74-WWHP3 if you look here. Then when you actually click "See Prices" you'll see some colored squares to choose your color and it's the beige/white looking one. When you hover over it, it should say "Warm White". Just make sure you click the right one before checking out.
http://www.superbrightleds.com/cgi-b...2F74-xHP3.html
Old Jul 5, 2011 | 10:15 PM
  #472
Thanks bro much appreciated, so these are just directly swap correct no modification at all.
Old Jul 5, 2011 | 10:19 PM
  #473
SeedyROM's Avatar
Correct. Twist out old ones, pop bulbs out and insert LEDs, twist back in. Might have to flip the LED in the socket if they don't light up since they only go one way.
Old Jul 5, 2011 | 10:22 PM
  #474
Cool man just placed the order can wait to slap these babys in
Old Jul 6, 2011 | 09:49 PM
  #475
laxmax's Avatar
i'll try to get some pics up soon but ya it was the same bulbs
Old Jul 6, 2011 | 10:09 PM
  #476
SeedyROM's Avatar
That would be great
Old Jul 10, 2011 | 10:34 AM
  #477
Rochester's Avatar
Always nice to see quality photography. Well done, Tomcat.
Hmm... "tomcat". Java geek, maybe? Or fighter-jet enthusiast?
Or maybe you just like cats?
OT... yeah. Sue me.
Old Jul 11, 2011 | 07:56 AM
  #478
NmexMAX's Avatar
dot dot dot ...
Yeah, they are not inverted like the OEM ones are... The contacts are on the wrong side.
I managed to keep 2 OEM sockets in decent shape, so my gauges look good, now I'm just missing the trip and temp bulbs.
There may be a way to make the Hong Kong bulbs fit. Let me know what you find for replacements.
Old Jul 11, 2011 | 09:01 AM
  #479
Ordered the ones from Amazon still from Hong Kong but different company hope they work going to give them a shot in a day or two just have to find where the hell I put the LEDs....
Old Jul 12, 2011 | 05:17 PM
  #480
ChiTeMax's Avatar
EDITED.
I should've read the entire thread. Found the answer.
