How to change drivers side headlight harness on a 2000 SE with auto lights
Old Apr 17, 2011 | 09:01 PM
gakary54's Avatar
The plastic housing around the plug melted and my low beams do not work. The high beams still work. Is the harness removable or do I need to cut and splice?
Old Apr 18, 2011 | 11:22 PM
fatboyslim86440's Avatar
harness to headlight bulb??
cut factory connector and splice in a new one would be route one...
Old Apr 18, 2011 | 11:28 PM
gakary54's Avatar
Thanks, it's what you plug the headlight bulb into. The 2 slots on the side are fine, the one on the top has melted off. I was just wondering if the connector was removable as in a plug. I saw a listing on ebay for one that is "plug and play", but I guess cut and splice is my only option.
Old Apr 22, 2011 | 02:49 PM
2k0Maxima's Avatar
First you want to find out why its melted. Because if you plug and play it will probably melt again, same for slicing.
Old Oct 19, 2011 | 06:29 PM
anoor's Avatar
I have the same problem with 2000 maxima. The driver side headlight stop working. Changed the bulb worked once and now not working looked at the connector and od not see anything wrong. Tried to measure the voltage on all three connector and no voltage. I checked the switch box and do not see any fuse in the fuse socket. The passenger side headlight works fine. What do I do?
Old Oct 19, 2011 | 11:51 PM
Mr. Blue Sky's Avatar
If you are using higher wattage bulbs, the melting will continue to occur. You need to figure out what is causing this problem first(could lead to big problems down the road if your wires are getting super hot)
fastcarny
May 18, 2020 10:40 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
rtirbany
Sep 8, 2015 11:46 AM
98nismomax
Aug 13, 2015 12:44 PM
