Stripped airbag torx screw
Old Apr 22, 2011 | 05:51 PM
kdarcangelis870's Avatar
So today when I was trying to remove my driver's side airbag to investigate a clunking noise from the steering damper I wound up rounding off the left side torx bolt. I thought about using a grinder to make a slot for a flat blade screwdriver but there is no room to do so without damaging the rest of the steering wheel. Any ideas?
Old Apr 22, 2011 | 08:20 PM
nelledge's Avatar
"I'm just sayin'..."
Proper size drill bit and screw extractor. Take your time, use a variable speed drill, and use high torque setting with a low speed. Be patient. It'll work.
Old Apr 22, 2011 | 09:17 PM
bds1304's Avatar
sounds like u got a problem
Old Apr 23, 2011 | 09:10 AM
Alright, I think i will head out and buy an extractor kit today. And one more thing, since i am pretty much going to destroy this screw, does anybody know where i can find a replacement?
Old Apr 23, 2011 | 10:39 AM
datsunzcar84's Avatar
Just take one of the goods bolts to Lowes . They have a board with different screw sizes so you can tell what thred pitch you need .
They will have one that works and it will be a few cents.
Old Apr 23, 2011 | 11:46 PM
DennisMik's Avatar
This. Just about all hardware stores have metric nuts & bolts. Replace all the Torx with hex head so it will be easier next time.
Old Apr 24, 2011 | 07:52 AM
Ghost_54's Avatar
Or,, if you have access to a small dremel tool you could then use the grinder wheel and make the slot for a flat head screw driver ... either way like you said your going to wind up destroying the bolt and will need a replacement.
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
sliptap
Sep 30, 2015 05:57 AM
Colossus
Sep 9, 2015 05:46 AM
