wont run with maf sensor unplugged
Old May 1, 2011 | 12:33 PM
sticky's Avatar
im still having trouble with my 01 se auto,so i thought i unplug maf for the heck of it and it wont run,i have done it on other cars they would run,i have checked wiring harness i have ohmed tps,iacv,rebuilt ecm,unplugged motor mounts,new maf,air filter,,cleaned t/b tryed relearn still will only rev to 1800 rpm warmed up,surging up and down 3500 rpm cold up and down
Old May 1, 2011 | 06:02 PM
DennisMik's Avatar
If you still have the maf unplugged and the car runs like crap, that's exactly what you should get. If you plugged the maf back in and the car runs like crap, then you have a problem. Get the code pulled out of the ECU and let us know what they are.
Old May 1, 2011 | 06:33 PM
2000_MAXIMA_KING's Avatar
Too bad I didn't understand anything you posted because its jibberish so I can't help you.
Old May 1, 2011 | 06:52 PM
AutoGaugeMax's Avatar
If your trying to say that you disconnected the maf and tried staring the car and it now fails maybe you should reset the ecu. Good luck
Old May 1, 2011 | 07:12 PM
junglee Z's Avatar
here's what i understood: i'm having troubles with my 01 se auto. so i thought i would unplug the maf just for the heck of it and now it won't run. i have checked wiring harness, ohm tested the tps, iacv, rebuilt ecm, unplugged the motor mounts, new maf, air filter, cleaned t/b, tried relearn procedure. it still only revs to 1800 rpm surging up and down when it's warm, and 3500 rpm when it's cold.
did you ever plug the maf back in? i don't you clarified that for us.
also, there is a tool called spell check. use it.
Old May 3, 2011 | 12:36 AM
sticky's Avatar
too bad they dont have a writing tool i dont you clarified that
Old May 3, 2011 | 12:56 AM
roggeezy's Avatar
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
