horn dead on drivers side
Old May 3, 2011 | 05:12 PM
Martin's Avatar
No power to horn on drivers side
The horn that chirps when the locks are set doesn't work. It's not the "remote programming" fix.
There are 3 relays that check out OK. The horn works fine on test but is not getting 12V from the plug when the horn is blown. Any ideas?
Thanks in advance, Martin
Old May 3, 2011 | 05:51 PM
CMax03's Avatar
Is power leaving the relay? Swap relays...... check fuse......
Old May 3, 2011 | 08:18 PM
Professor's Avatar
10 amp fuse in the fuse panel under the hood.I think its labeled security. mine when out when i installed higher power horns.
Old May 4, 2011 | 05:34 AM
Martin's Avatar
Nope to both posts. Fuses are OK as are the relays. All 3 Relays were removed and bench tested.
Old May 4, 2011 | 01:23 PM
Professor's Avatar
Run a wire from the battery + to the horn and see if it sounds, if not, theres your problem.
Old May 4, 2011 | 03:36 PM
Martin's Avatar
Horn works fine wired direct to battery.
Old May 4, 2011 | 05:07 PM
Martin's Avatar
OK - problem solved.
I missed the fuse marked ANTI THEFT located at the bottom RT hand corner in the fuse panel beside the battery. Close inspection revealed corrosion on the spades and the fuse blown right at the corner not the middle. I suspect the corrosion caused a poor connection which spiked the current when the doors were locked and horn chirped.
Thanks to all that helped.
Martin
boomerbrian
Oct 31, 2018 10:25 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
Colossus
Sep 9, 2015 05:46 AM
FanaticMadMax
Sep 4, 2015 02:45 PM
maximusrising
Sep 2, 2015 09:55 AM
