2002 Difficulty starting, hair pulling out
Old May 4, 2011 | 05:58 PM
slydel's Avatar
I searched and done everything I know.
Briefly, engine died a few times and went to idle, I changed the Cam Sensors.
Engine had trouble starting but ran well. Then at night the battery went dead on a test run. I replaced the alternator, charged battery, started, ran like a scolded cat, but then requires 30 seconds of cranking to get started again each time now.
Please help.
1. Ground is good.
2. 202k miles.
3. K+N filter is clean.
4. gas is good.
5. Fuel pumps sounds fine, buzzes with ignition and the stops, as it has done since new.
Old May 4, 2011 | 06:31 PM
Stormzusmc's Avatar
CEL? Battery load tested/replaced?
MAF, plugs, coilpacks, there is a number of things...do a compression test as well
Old May 5, 2011 | 11:35 AM
maxima dude's Avatar
sounds like a crank sensor to me
Old May 5, 2011 | 02:17 PM
fatboyslim86440's Avatar
+1
Old May 5, 2011 | 02:37 PM
Stormzusmc's Avatar
that would pop a code for sure...so again cel?
Old May 5, 2011 | 08:26 PM
slydel's Avatar
I had a cam sensor code and the P1800 code, I disconnected the VIAS thing and plated it off.
I have a crank sensor that I bought in error, maybe I should change that and see, thanks.
Old May 23, 2011 | 02:26 PM
slydel's Avatar
Well, I finally changed: Alternator, Crank/Cam sensors, I then did comp test, which was perfect, it was at that point I realized I had never changed the plugs.. Voila!!
The problem is solved. 202k miles on factory plugs, they were all worn down and generally crap, what a maintenance slob I can be
Old May 23, 2011 | 02:51 PM
spock's Avatar
Over 200 k on the plugs? And you're asking for help, pulling you're hair out? I hope this taught you a little something.
Old May 23, 2011 | 03:21 PM
slydel's Avatar
I hope so, I'm too old to be this dumb
Old May 23, 2011 | 06:29 PM
homeyclaus's Avatar
Doh!
Kudos to you for admitting your mistake on a public forum. So that others may learn.
Old May 23, 2011 | 06:35 PM
spock's Avatar
All's well that ends well. That's the beauty of the org.
Old May 29, 2011 | 08:24 PM
IVIaxima's Avatar
i kinda have somethen similar... it only happens when its cold.. When i start it up in the morning and just put it in drive and go it wants to stall.. my rpms drop about to 400 rpms but if i give it a little gas it acts normal its only when its idleing...BUT if i let it warm up and drive it it doesnt hesitate it just goes... i already replace the crank sensor by the pully but ik there is a second one(not exactly sure where it is) when i put the the crank sensor in and started it it didnt hesistate as much as it used to so im debating on changing the second one.... any advice?
Old May 29, 2011 | 08:56 PM
T_Behr904's Avatar
markevans999
Sep 10, 2015 04:29 PM
boomerbrian
Sep 4, 2015 08:25 AM
trungg86
Sep 4, 2015 04:58 AM
crazyespn
Sep 3, 2015 01:30 PM
Justin Kroll
Sep 2, 2015 11:06 AM
