installing airbags
Old May 6, 2011 | 08:37 AM
beefster's Avatar
installing airbags
So i've been meaning to put in my a used set of airbags for a while (mine are blown and stitched up like frankenstien)
im wondering can i install them my self with the mod
or should i get a mechanic to do it (and if i do go this route how much should it cost got quoted 120 before)
also my driver side seat belt is popped should i replace this to clear the light (passenger side works fine)
lil off topic,
to change serpentine/alternator belt how much does it cost to change some guy just quoted me 170 over the phone
Old May 6, 2011 | 08:54 AM
NAVY00MAXIMA's Avatar
Watch these and you tell us what it's worth. The belts cost $8-20 each. In the first vid he changes the belt in 7 minutes and I believe he films it all but I'm not watching it. I know how. The second vid is the PowerSteering belt.
http://www.youtube.com/watch?v=bJzpTHIky18
http://www.youtube.com/watch?v=L8c1ezfX4jo
Old May 6, 2011 | 08:55 AM
MadMax07SL's Avatar
For the Airbag, dealership or certified body shop. Most mechanic shops aren't certified to do the install, and will turn you away.
Even the seatbelt, typically the same thing. And you should consider this a good thing, especially with the AB's...you want to know that the installer knew what he was doing, and could test all the circuits correctly.
I bet a dealership wouldn't even touch used bags...you'll probably have to find a good independent body shop.
That said, call around, get prices. That's the only way you'll know what the local install price is...
Old May 6, 2011 | 09:01 AM
Be careful with airbags. If the sensor is damaged as soon as you hook it up it can deploy. The negative cable is suppose to be removed and let the car sit untouched for a half hour before anything airbag related is to be touched.
Old May 6, 2011 | 09:16 AM
DennisMik's Avatar
The airbags are like any other part on a car - there are certain things you have to watch out for. NAVY00MAXIMA outlined the airbag precautions. When you are working on your car and encounter a yellow wire harness connector, that is for the airbags.
Changing the seatbelt is a no-brainer. The only requirement is that you have the bolts tight.
And if you have basic mechanical abilities, you can change the serpintine belt. Being the first time, I'm sure it will take you more than 7 minutes.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
2kmaximel
Sep 16, 2015 03:19 PM
Colossus
Sep 9, 2015 05:46 AM
Johnny9595
Sep 3, 2015 05:18 AM
