CoryXavier Bop plate install how 2
Old May 16, 2011 | 06:12 PM
CXJ Performance's Avatar
Former Sponsor
Thanks to all who have brought my product. below are steps to install the bop plate.
tools needed:
flat head screw driver
rachet
extension
10mm socket
1/2 wrench
12mm gear rachet wrench ( very important you buy this if you dont have it )
ultra grey rtv gasket maker
zip tie
CoryXavier BOP kit ( hardware included )
step 1
remove engine cover
step 2
using 10mm socket , extension and rachet remove bolt holding wire harnes
step 3
using flat head screw driver press clip holding the harness to the metal bracket. be carefully not to break this while doing this. if so it doesnt effect the way the harness is positioned. just a fyi
step 4
remove the 12mm o.e.m bolts holding the V.I.A.S using a 12mm rachet gear wrench. bolt number 3 will be the hardest to remove. please use gloves and have patience for this bolt
step 5
remove V.I.A.S from manifold
step 6
remove air line from V.I.A.S and zip tie to air line still connected to the manifold.
step 7
clean oil from V.I.A.S area to ensure rtv gasket maker has a clean surface for sealing
step 8
apply rtv gasket maker to mainfold area of where the V.I.A.S was removed. best way is to apply by finger to ensure a leveled amount
step 9
install Bop plate
step 10
using the bolts that came with the kit install the bop plate.
step 11
hand tighten bolts and wipe off any excess gasket maker that may have been pressed out
reverse steps
enjoy the new hps from this mod.
now the legals
Lawyers made me do it
I CORYXAVIER MAKE NO WARRANTY, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO ANY WARRANTY OF MERCHANTIBILITY OR FITNESS FOR ANY PARTICULAR PURPOSE WITH RESPECT TO THE MARKETING AND SALE OF THE CONTENT. UNDER NO CIRCUMSTANCES SHALL CORYXAVIER BE LIABLE FOR ANY INDIRECT, INCIDENTAL OR CONSEQUENTIAL DAMAGES (INCLUDING LOST PROFITS) INCURRED IN CONNECTION WITH THE USE OF THE INFORMATION OR PRODUCT STATED ABOVE. NEITHER CORYXAVIER NOR PARTNERS SHALL BE LIABLE FOR DAMAGES CAUSED OR ALLEGEDLY CAUSED BY FAILURE OF PERFORMANCE ERROR, OMISSION, INTERRUPTION, DELETION, DEFECT, DELAY IN OPERATION OR TRANSMISSION OR COMMUNICATIONS LINE FAILURE INVOLVING THE CONTENT.
Old May 17, 2011 | 09:24 AM
Mr. Brett's Avatar
Dude...that's a sh*tload of RTV. You have enough there to make four or five gaskets.
Also, for the sake of cleanliness, why not use an OEM VIAS gasket from Nissan? I doubt it costs very much, couldn't be much more than the RTV.
Old May 17, 2011 | 10:19 AM
NmexMAX's Avatar
dot dot dot ...
The late A34 model (as seen in this tutorial) also uses a plastic valve. All the more reason to chop/hack it.
5.5 gens use a metal (Al) valve, as we all know as well as a metal reusable gasket.
Old May 17, 2011 | 10:25 AM
Rochester's Avatar
The 5.5 VIAS valve is a different design, too. Here's one off an engine that is actually clean...
Old May 17, 2011 | 10:32 AM
Rochester's Avatar
Originally Posted by NmexMAX
at least 90% of us could do this while blindfolded
That's an optimistically high percentage.
Honestly, I think $20 is a fair price for a VIAS-delete BOP. Although flange-head, SS bolts would be more appropriate. That, and a little restraint on the RTV.
Old May 17, 2011 | 10:41 AM
NmexMAX's Avatar
dot dot dot ...
You & your bolts, cripes.
For the 5.5 gen it's 3 bolts, that's it, nothing more or less..
Old May 17, 2011 | 07:13 PM
CMax03's Avatar
Again the hardware lacks any type of lockwasher or plain washers @ that!!!!! You erased me previously why?????? (Moderator)
Old May 17, 2011 | 10:26 PM
96blkonblkse's Avatar
IMO Id rather re-use the stock 12mm and put a washer on than use 1/2" head bolts. Im kinda picky but i hate when i look in and engine bay and see a mix of different bolts. If the car uses metric sized bolts, than only metric sized bolts should be used lol.
Old May 18, 2011 | 06:19 AM
NmexMAX's Avatar
dot dot dot ...
I didn't erase anything, haven't done any editing in this thread aside from my own posts.
Old May 18, 2011 | 06:40 AM
DanNY's Avatar
Ad·min·is·tra·tor
PM me if there's a problem here otherwise keep it ON TOPIC.
thanks,
Dan
Old May 18, 2011 | 07:42 AM
Rods03Max619's Avatar
Looks pretty good is it made of plastic orsome kind of metal...
Looks pretty good is it made of plastic or some kind of metal...
Old May 18, 2011 | 08:10 AM
Former Sponsor
its made out of 1/4 aluminum. and painted in 500 degree engine enamel black
the stock bolts will not work when installing the bop plate thats why i include the shorter bolts and the bolts thread used are metric its the head thats standard 1/2"
if washers are a concern its 33 cents for them. its doesnt impact the bop plate at any rate
Old May 18, 2011 | 10:51 AM
Rochester's Avatar
This would get more attention from 5th and 6th genners alike if it were moved to the Group Deals/Sponsors forum.
Old May 18, 2011 | 11:57 AM
Kevlo911's Avatar
Kevlo for President
Why is this a sticky?
Old May 21, 2011 | 07:49 AM
CMax03's Avatar
Sorry, maybe I didn't submit the b!tch!!! I apologize Nmex... My bad!
Old May 22, 2011 | 12:50 PM
T_Behr904's Avatar
Too bad the De-K's aren't this simple...
Old Jun 9, 2011 | 11:30 AM
Truff02's Avatar
Looks good man! I'll DEF be grabbing one of these tomorrow.
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
Maxima Pride '07
Sep 12, 2015 07:29 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
