No Spark
Old May 17, 2011 | 11:43 AM
aleem's Avatar
No Spark
2k maxima 150k. I have a starting issue, new battery, started crank sensors, plugs, coils and cam sensor. Also checked for continuity between ecu and sensors. On the first crank i get a spark. If i hold key down i get no spark. If i bump the key i get a spark only in the first crank. Basically i am not getting a continuous spark. Im thinking ecu maybe the issue. Any Ideas?
also all fuses and relays are good. ty
Old May 17, 2011 | 02:40 PM
MerlotMax's Avatar
Could be a bad key chip or the immoblizer in the steering column that picks up the signal from the key.
Old May 17, 2011 | 04:51 PM
aleem's Avatar
Would the security light stay on?
Old May 18, 2011 | 06:38 AM
MerlotMax's Avatar
sorry - not sure of that.
Old May 18, 2011 | 07:36 AM
Jliner's Avatar
is the vechicle throwing any codes ?
Old May 18, 2011 | 08:22 AM
L36's Avatar
L36
Personally id suspect this being a immobilizer issue.
Old May 18, 2011 | 12:14 PM
aleem's Avatar
no codes. how do i troubleshoot immobilizer?
Old May 18, 2011 | 01:13 PM
hondaeatingtsi's Avatar
the security light should stay on if its a immobilizer issue. at least thats the way in works on all the acuras that i have worked on. but most of the time the car wont even get a signal for the starter so it shouldn't crank at all.
so with that being said i would lean more to the ecu being the issue being that it cranks but has no spark.
Need help
23
Oct 2, 2015 08:56 AM
Gingerheadman
Oct 1, 2015 05:11 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
