timing tensioners
Old May 17, 2011 | 11:44 AM
PatKeo6373's Avatar
timing tensioners
i got a bad cam chain tensioner and this job calls for 12hrs. i know alldata is usually b/s on labor times and theres usually a short cut.
does anyone know if u lay the timing cover to the side if there is enough room to get to the cam chain tensioners
Old May 17, 2011 | 02:51 PM
Lsgun1's Avatar
You have to fully remove the timing cover to replace the tensioners. It will fit out with the engine in the car it's just tight.
Old May 17, 2011 | 04:55 PM
aleem's Avatar
also you will have to remove valve covers to get to the tensioner that hold the small chains
Old May 17, 2011 | 07:08 PM
CMax03's Avatar
If you're gonna do all that just replace the chain guides, tensioners, sprockets, all of it..........and be done with it!!!! Laying the timing cover sounds like a good way to warp it and it will never be seal tight after you lay it to it's side.......
Old May 18, 2011 | 10:30 AM
PatKeo6373's Avatar
all that was replaced i just ran out of money when i bought the variable sprokets damn things werent cheap and needed the car to get to class and work. so of course because i tried to cut a corner the one of the two tensioners i didnt replace failed 8months later.
Old May 18, 2011 | 12:13 PM
aleem's Avatar
i bought a timing kit for 200. it came with everything.
Old May 18, 2011 | 12:15 PM
NmexMAX's Avatar
dot dot dot ...
For a VQ30 yes, I bought one a few years back for my 95 for about 180 or so.
The VQ35 has the lovely CVTC sprockets and associated assemblies on the I side.
Old May 23, 2011 | 02:40 PM
max611's Avatar
When should all this be done? mileage wise...
Old May 23, 2011 | 05:00 PM
ELGUPASO's Avatar
i want to know the same. my maxima has 132k miles. i hear no rattle noise or anything like that. so i figure my timing chain is still good and tight.
Old May 24, 2011 | 06:13 AM
NmexMAX's Avatar
dot dot dot ...
You've got the right idea.
If it ain't broke, don't fix it.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
Wareagle92
Sep 3, 2015 07:18 PM
