Need some help with a strange problem.......
Old Jun 21, 2011 | 02:09 AM
gakary54's Avatar
I parked the car, shut her off and left her for about 20 minutes. I come back out and try to start her, but all I get is a quick screeching noise and then nothing. I get a jump about 40 minutes later and she starts right up, but now my keyless entry, power door locks and rear defroster don't work. I check my fuse panel inside the car and find 2 fuses for the defroster, but none for the door locks. I'm assuming that the keyless entry is tied in to that. Can anyone shed some light on this issue? Thanks.
Old Jun 21, 2011 | 08:46 AM
Flanker84's Avatar
Did you search in the Engine Bay?
If I remember well the keyless entry it's in the engine bay area.
Old Jun 21, 2011 | 09:16 AM
VQP0WER's Avatar
You are addressing the battery/alternator issue as well, correct?
Old Jun 21, 2011 | 09:45 AM
DennisMik's Avatar
Fuses 12 & 13 in the dash (both 10 amp) are for the door locks. Under the hood by the battery is a 10 amp fuse labeled anti-theft.
But the only thing that I can think of that has the door locks and the rear window defogger in common is the SECU (Smart entrance Control Unit). There are a lot of fuses that feed the SECU. Check fuse 10.
Old Jun 21, 2011 | 11:14 PM
mrjamaica98mx's Avatar
It;s the SECU disconnect and reconnect u may have to buy one i had to buy two before i got mines to work.
Old Jun 24, 2011 | 03:28 AM
gakary54's Avatar
Changed the 2 fuses for the defogger, no dice. I was hoping it would be something simple. Where is the SECU located?
Old Jun 24, 2011 | 04:20 AM
VQP0WER's Avatar
Under the dash- drivers side-near center console.
There's a picture of it somewhere on the forums here....
Old Jun 24, 2011 | 02:46 PM
DennisMik's Avatar
Here's a picture of my 00 Max -
Old Jun 26, 2011 | 07:33 PM
gakary54's Avatar
After reading this, I go out to my car. Keyless entry is still not working. I put the key in and start it and D/L's and defogger are still not working. I shut the car off, leaving the key in the ignition. I check the fuses in 10, 12 and 13. All of them are good. As I reinsert the fuse in 13, I hear the key-in-ignition warning chime. Now everything works. Go figure. I am going to get the starter and battery replaced this week. Thanks to everyone for their help.
Old Jun 26, 2011 | 07:36 PM
trooplewis's Avatar
Why?
Old Jun 26, 2011 | 07:40 PM
gakary54's Avatar
The starter was the reason this problem began, it hesitates when I try to start the car in the morning. After that it seems to work fine. Rather not take any more chances with it. The battery looks old, I have no idea when it was replaced last. Now is as good of a time as any.
Old Jun 26, 2011 | 08:37 PM
trooplewis's Avatar
Try replacing the battery first, the starter might be fine.
Hondarydr
Dec 30, 2024 06:15 PM
tarun900
19
Dec 20, 2021 06:57 PM
Chebosto
Sep 11, 2002 05:36 AM
Cumalot
Feb 21, 2001 10:01 AM
