STUPID FAN!!!!!
Old Jun 22, 2011 | 06:15 PM
BLACKKILA.GTR's Avatar
STUPID FAN!!!!!
ight for some weird reason my second fan wont come on.. its suppose to come on when the a.c is on correct>?
i changed it out wit a new fan and the same thing the thing does not come on... ( looking at the engine the right fan comes on but not the left)
now heres where my mind draws a blank when i turn my a.c on it runs well when im driving ... when the car is in park for a lil while i think the a.c clutch disengages and my ac starts blowing hot air...
check the left and right fan fuse under the hood and they are both good...
any ideas on what might be up???
Old Jun 23, 2011 | 08:30 AM
kvk2003max's Avatar
I had the same issue and it turned out to be a blown fuse for the 2nd fan.
Old Jun 23, 2011 | 09:11 AM
Bassbreaker's Avatar
Yea, it still could be the fuse. Some may LOOK ok, but internally the're shot. Try swapping it out with a different one and see whats up
Old Jun 23, 2011 | 05:30 PM
i swapped the fuses around while the fan was on with the fuse that is suppose to be bad and the fan still worked..
Old Jun 23, 2011 | 07:17 PM
cabernet's Avatar
In the box next to the fuse box there are 3 fan relays as I remember. One of them may have gone bad.
Have you tried taking the electrical connector from the non-working fan and plugging it into the fan that works? If the previously working fan now doesn't work then it is most likely a fuse or relay.
Old Jun 23, 2011 | 10:15 PM
DennisMik's Avatar
Both fans should always run at the same time, never just one.
In the box in front of the battery are the fan relays.
Fan Relay 1 controls the low speed on both fans.
Fan Relay 2 controls the high speed for the fan closest to the battery.
Fan Relay 3 controls the high speed for the fan towards the passenger side.
Since the fan doesn't run when you turn on the a/c, Fan Relay 1 is the suspect. Swap it with either relay 2 or 3 and see if this helps.
As to the a/c compressor stopping, this could be normal. The ECU will turn off the a/c if the engine temperature is getting too hot. When the car is stopped, the radiator fans have to do all the cooling. When you're moving, the car's speed gives you air flow through the radiator.
Old Jun 24, 2011 | 12:52 PM
cool.... im gonna test that today will update what i discover
Old Jun 24, 2011 | 01:50 PM
swapped fan 1 relay with another fan relay and both fans are on now which means i bought a new fan for nothing..smh... its cool extra parts
off to auto zone to buy a new relay
thanks man !!!!!!
Old Jun 24, 2011 | 06:32 PM
well its doing it again... this time i tried all the relays in different sockets and they all see good the second fan is not comming on... fan one is running fine and its speeds up when it should but nothing from fan 2.. im stumped
Old Jun 26, 2011 | 01:27 PM
anyone have an idea
Old Jun 27, 2011 | 12:24 AM
DennisMik's Avatar
When you first swapped relays and the fan came on, this may indicate that there is some kind of bad connections in the wiring in the relay box. As you swapped relays, you wiggled things. But I don't see a clear cut pattern to this as it takes 2 relays. I don't know the physical construction of the relay box and how it connects into the wire harness. If the relay box uses a connector, then this would be suspect.
Otherwise, pull out the fan relays and look carefully at the wires in the socket that the relay plugs in to. Look for wires that look to be deeper in their hole than the others. Check the fuses again, maybe something happened to make it blow.
Miket2006
Mar 1, 2021 03:55 AM
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
asianstyle
Sep 10, 2015 11:30 AM
