LED tail signal install - fail so far.
Old Jun 26, 2011 | 01:40 AM
Saadkhan07's Avatar
Ordered these new LEDs for my signals.
Installed them both, and was having issues. If both installed, when i press the brakes every light in the car turns on. I know that there should be a extra resistor installed in the tail light harness. Anyone know the type of resistor, how to install, etc etc.
I tried searching on the forum, had no luck. I would appreciate it !!
Old Jun 26, 2011 | 03:28 AM
JonBlz's Avatar
a.k.a. STuNtMAN
these are the ones i used
http://cgi.ebay.com/ebaymotors/2-NEW...Q5fAccessories
Old Jun 26, 2011 | 06:17 AM
03VQMAX's Avatar
Or this http://cgi.ebay.com/Electronic-LED-I...item5ad7970ae6
Old Jun 26, 2011 | 08:44 AM
mrpopo573's Avatar
I always get the flasher module ^
Way cleaner of an install and allows for 4 LED bulbs.
Old Jun 26, 2011 | 10:28 AM
03VQMAX's Avatar
Regardless of the relay or resistors, none of the dash lights should be turning on?
Old Jun 27, 2011 | 12:43 AM
DennisMik's Avatar
The resistors are so you can use the stock turn signal flasher, not having them has nothing to do with your problem. What I think is happening is that when you step on the brakes, the electricity is somehow feeding into the other wires. Remove the led lamp and very carefully compare the base of it with the regular lamp you took out. Make sure that the little wires on the base are perfectly straight and not touching another wire.
Old Jun 27, 2011 | 02:21 PM
Saadkhan07's Avatar
re
The lights arent coming on anymore because i put the stock bulbs back in until the resistors come.
Now im getting a bulb out error on my dash. I think i replaced one of the LLs with a regular bulb (as LL are used for brake lights)
So just need a resistor, and a wire cap to do the trick ? any side-effects or anything cautionary i should know ?
Just splice, twist, and connect ?
Old Jun 27, 2011 | 07:09 PM
TunerMaxima3000's Avatar
Sounds to me like you put them in the brake light location, or the brake AND the signal, not JUST the signal location.
And great advice to get the Relay, dumb to install resistors IMO, buy the flasher unit.
Old Jun 28, 2011 | 11:15 PM
Saadkhan07's Avatar
re
Buying the resistors would be a cheaper alternative than spending $30 on flasher units alone...unless they can be purchased for cheaper
Old Jun 28, 2011 | 11:26 PM
Saadkhan07's Avatar
re
Originally Posted by JonBlz
Ordered these. Thanks for the link. Just splice, and wire em up ?
Thats all ?
Old Jun 29, 2011 | 07:10 AM
03VQMAX's Avatar
Yes that's all, but you should've waited for a cheaper link, http://autolumination.com/equalizers.htm
Old Jun 29, 2011 | 08:09 AM
The6spdMax's Avatar
Thats all ?
Yes.
Yea, I bought them from this website as well. I used to get hyper flash when I had my led turn signals. You will need two (one for driver and passenger.) I just tap them into the signal wires from the trunk because it has more room (both wires should be behind the gas door in the trunk), tap one side of each resistor to each signal wires and just ground the other side to the chasis for ground.
Old Jun 29, 2011 | 01:47 PM
mandyfig's Avatar
Resistors seldom work. You will still get the Burned bulb light.
Old Jun 29, 2011 | 02:50 PM
03VQMAX's Avatar
Originally Posted by The6spdMax
Yes.
The link was actually for the Relay, I guess the resistors are at the bottom of the page.
Old Jun 29, 2011 | 04:36 PM
Saadkhan07's Avatar
re
Im getting the burned bulb light right now because one of my brake lights actually did go out (bulb is burnt)
The flasher relay, do you only need one of them ? and i guess they just replace the stock unit, right ?
Should i go ahead and get the flasher unit ? it will be a easier install, but it shouldnt mess up anything right ?
LMK
Old Jun 29, 2011 | 04:42 PM
mrpopo573's Avatar
I have an LED flasher module for my set up. It is a cleaner and better way to have LED brake/turn signal bulbs. It doesn't mess anything up.
Old Jun 29, 2011 | 05:11 PM
03VQMAX's Avatar
+1, exactly what he said, it's plug n play, no splicing. Although the tick is a bit louder than stock and the signal speed is a tad bit faster than stock, but no hyper flashing.
Old Jun 29, 2011 | 05:53 PM
Saadkhan07's Avatar
re
Ok. I think i might just buy the flasher unit. Id rather have my wires intact rather than them being cut up etc. Which flasher unit should i get ?
Also, only need one, right ? Also, in the relay, where does this fit ?
Thanks !!
Old Jun 29, 2011 | 05:56 PM
mrpopo573's Avatar
Thanks !!
You need to get a Maxima (Nissan) LED Flasher. Ebay/google shopping will have them. It takes the place of your factory flasher unit which is near your steering column above the drivers feet area. Removing the lower part of the dash with two phillips screws gives you a clear view, though I was able to replace it without doing that.
Old Jun 29, 2011 | 06:08 PM
Saadkhan07's Avatar
re
So on this site - http://autolumination.com/equalizers.htm
Choose the nissan one, Correct ?
Old Jun 29, 2011 | 06:10 PM
Ummm, nope. You can get LED flashers for under $5 off ebay, and local part stores for under $16.
Resistors you can purchase cheaper, yes, but they will overheat and burn things, to buy the PROPER resistors you need the ones that have a heat sink board with cooling fins, etc. Those are at least $8 each, not to mention the extra wiring, mounting, and so on. Silly way to do it when you can just get a flasher module for so cheap, and it's so easy to replace.
There really isn't any argument... just get the Flasher.
mrpopo573's Avatar
Yes. that is the exact place where I got mine, and the exact flasher module I got.
Old Jun 29, 2011 | 06:23 PM
Saadkhan07's Avatar
re
Would you mind posting a video of your lights flashing...i would highly appreciate it. Ill take this over the resistors (already ordered them =( ) because you can change all the bulbs without adding anything additional.
Thanks !!
Old Jun 29, 2011 | 06:32 PM
mrpopo573's Avatar
Thanks !!
Won't be able to do that. But google some videos up or go on youtube. The bulbs I used were from vleds.com (Local Washington State Seller.) great stuff.
Old Jun 30, 2011 | 12:10 AM
Saadkhan07's Avatar
re
Now one more small question, If you do it with the resistors, does it alter the flash rate ? make it better/worse or stay the same ?
Thanks again.
Old Jun 30, 2011 | 06:16 AM
03VQMAX's Avatar
Thanks !!
I'll see if I can, it's been raining for 2 days straight.
Old Jun 30, 2011 | 06:17 AM
03VQMAX's Avatar
Thanks again.
With the resistors, flashing rate and sound will stay the same since your not changing the flasher module. I've installed some on my fathers front signals on his F150 about 4 yrs ago, still flashing normal.
Old Jun 30, 2011 | 03:24 PM
Saadkhan07's Avatar
re
Resistors came in today. Going to play with my lights tonight when i get home. Ill post up pics/video when im done with it.
You guys have been a great help. I appreciate it big time !
Old Jun 30, 2011 | 03:35 PM
Saadkhan07's Avatar
re
Old Jun 30, 2011 | 11:33 PM
Saadkhan07's Avatar
DONE !
http://www.youtube.com/watch?v=mIebfP5AoaI
Old Jul 1, 2011 | 09:00 AM
Was it worth the work? I bet not.
Old Jul 1, 2011 | 09:25 AM
mrpopo573's Avatar
It was for me when I did it. However, this was the 4th car I've done it to and I didn't struggle as much as the OP.
Old Jul 1, 2011 | 09:53 AM
mandyfig's Avatar
Nice, real nice! Can post a DIY?
Old Jul 1, 2011 | 11:03 AM
mrpopo573's Avatar
1. Buy LEDs
2. Buy LED flasher module
3. Install bulbs like you would normally install any replacement bulb.
4. Replace factory flasher module with LED Flasher
5. Enjoy
Please also check out my spotlight mod DIY here:
http://streakr.dkyhair.com/wp-conten...0/09/fixed.jpg
Old Jul 1, 2011 | 04:15 PM
Saadkhan07's Avatar
Actually, the work wasnt hard at all. it was quite easy. i thought it would be much more complicated, but its simple. I got the quick splice connectors which worked out great.
Next project will be the brake tail lights.
Old Jul 1, 2011 | 07:14 PM
*Facepalm*
Those things should be illegal. Because you've only used them in the trunk, you should be ok, but still.... horrible. Not as bad as the guys that use them in the engine bay and exterior locations.
Please, please, please, never use scotch locks
OAN I'm sure those look better in person, I didn't intend to sound mean or anything I realize it came across that way, they just look pretty much the same from the vid...
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
