On the four position switch, off works, and when switching to low and medium I hear the heat or AC switch on, but there's no fan action until it gets to high... and high itself works fine. Anyone else have this happen on a base 5th gen HVAC setup? What's my path to a solution here?
Quote:
Blower motor resistor. These are classic symptoms.Originally Posted by sixteenXnine
Just replaced the blower motor resistor on my dad's camry. He had the exact same problem, fixed it 100%. Was like 15 dollars
Can't recall, are they the same as the one's on the 5.5? If so, you can just remove resistor board, solder where it popped, and it'll work again.
Quote:
details in FSM?
Part #27077 in the guide:Originally Posted by 5150pa
Where is the resistor located?details in FSM?
http://www.courtesyparts.com/maxima-...1996_2012.html
