Both Low Beams Stopped Working
Old Jul 17, 2011 | 11:26 PM
cabernet's Avatar
All lights were working fine and then all of a sudden both low beams won't turn on. The high beams work fine. I doubt both bulbs would go out at the same time. Could it be the switch on the steering column or a fuse?
Old Jul 18, 2011 | 12:03 AM
CMax03's Avatar
True that! Check the fuse, the bulbs and the headlight/turn signal stalk.........
Old Jul 19, 2011 | 09:44 AM
Andy2000max's Avatar
Pull one of the bulbs and check the low beam filament. I had an alternator on it's way out that surged and it fried both low beams at the same time and one fog light.
Old Jul 19, 2011 | 10:17 AM
DennisMik's Avatar
There is one fuse for the left headlight and another for the right headlight. So if the fuse blows, you would not have low or high beam for that side. Same comment applies for headlight relays.
I have to think either 2 bulbs or the headlight switch.
jerrod99_se-l
Aug 27, 2015 08:27 PM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
egali045
Aug 16, 2015 01:19 PM
MikesChevelle
Aug 10, 2015 11:21 AM
kenc15
Aug 5, 2015 08:29 AM
