Screwed up with one of the front cross member bolts... what to do?
Old Aug 21, 2011 | 05:25 PM
xumengpeter's Avatar
Hi everyone, I have a 03 se..There r two big screws in front of the car which hold the cross member..I screwed up with one of them... it seems like stripped...and then i just screwed it in with an air tool.. it is not tight as the other one.... will there be any problem...? I know I`m an idiot...
Old Aug 21, 2011 | 06:14 PM
VQP0WER's Avatar
Is the bolt spinning? Cross threaded? When you say it's loose, is there still a gap between the bottom the bolt head and the cross member?
Old Aug 21, 2011 | 06:59 PM
i think i messed up the thread on the bolt...yes there is still a gap..u can rotate the washer between the bolt and the cross member...
Old Aug 21, 2011 | 07:55 PM
vybz05's Avatar
...you should probably get a new bolt.
Old Aug 21, 2011 | 08:53 PM
but i think the hole I screwed in is stripped as well..........thats the problem....
Old Aug 21, 2011 | 09:27 PM
Daniel1120's Avatar
Retap the hole. Find the bolt size and thread pitch then goto the hardware store and retap the hole, also inspect bolt to see if it needs replacing too. That should teach you for just hammer away with an impact.
Old Aug 22, 2011 | 02:22 AM
maxspeed96CT's Avatar
The original VQ...
I couldnt find a tap with the thread size of out crossmeber bolt , searched every harware store in my area.
Eneded up buying a few bolts from lowes that were a match and was able to chase them throught . Took a few tries , a air gun and a few bolts ..
Old Aug 22, 2011 | 05:01 AM
tcb_02_max's Avatar
I had the same thing happen to me. After retapping and buying a new bolt, it was good as new.
The last sentence above doesn't make sense, but FWIW I wasn't using an impact wrench.
Old Aug 22, 2011 | 11:07 AM
maybe ill have a mechanic to do it... dont have tools...
Old Aug 22, 2011 | 11:47 AM
V.S_Maxima's Avatar
It's a cross threaded bolt you'll need a new one gl
HOKUSMAX
Nov 13, 2017 04:34 AM
GregL65
Sep 5, 2015 09:37 PM
jfl330
Sep 4, 2015 01:44 PM
boomerbrian
Sep 4, 2015 08:25 AM
