R and R'ing my motor
Old Aug 25, 2011 | 07:13 AM
amack's Avatar
removing and replacing my 215k engine with a 80k one. its a 2000 5-speed SE, im replacing the clutch, plugs, wires, coil packs, just put a new starter on. what else would you replace while the engine is out?
phatboislim's Avatar
you're replacing spark plug wires and coil packs...man this ****s gona be fast
Old Aug 25, 2011 | 07:16 AM
NmexMAX's Avatar
dot dot dot ...
We have plug wires
Why are you replacing it again? VQ30's can go forever, literally.
Old Aug 25, 2011 | 07:18 AM
x2 i have 214k and mine sounds better than when i bought it with 117k, no bs
Old Aug 25, 2011 | 07:26 AM
NmexMAX's Avatar
dot dot dot ...
Let's check his profile, looks as if he may have PW'd to post this thread.
Old Aug 25, 2011 | 07:29 AM
looks like legitamate posts to me...this one speaks on why he needs an engine though
http://forums.maxima.org/8174687-post13673.html
Old Aug 25, 2011 | 07:33 AM
amack's Avatar
oops guys....im really not a noob to working on engines, just running through what is typical to need replacing when doing this...plus Im a little hungover this morning. anyhow, would you replace the timing chain and tensioner, water pump, thermostat? and yes I have a rod knock in the engine so thats why im replacing it.
Old Aug 25, 2011 | 07:36 AM
NmexMAX's Avatar
dot dot dot ...
Ya but posting every minute because you have a thought which could have been found by search is not cool.
1.) Give us some background information, not just blurt out ZOMMGGZZ!! I'm going to change me engine... For because why again?
2.) Do a little research instead of relying on spoonfeeding. dj's been patient enough with you.
3.) Red tag was with the plug wires statement. C'mon ..
Now, instead of us needing to go and search through all of your posts (phatboi's got the time, but most of us don't), either link us or explain, in full detail, your issues.
If you do this for your next thread, that will be nice and will uphold the confusion and keep you off my radar.
Old Aug 25, 2011 | 08:10 AM
amack's Avatar
NmexMAX, I understand how car forums work. I was asking a pretty general question I think. when any of you have replaced your 3.0 5th gen engine what would you replace? what is typical to fail on these engines right around 80k? the car is a 2000 5-speed SE. I bought it knowing that it needed a new engine. it has a rod knock. it starts but dosent stay running. as far as the wires and packs comment....ok, my bust honest stupid mistake. Also, the posting everytime I have a thought, not me I just wanted to get the stupid restricted 15 posts out of the way. Any help would be appreciated guys, Im gonna need some tech help along the way with this car to be a proper DD. thanks in advance.
Old Aug 25, 2011 | 08:12 AM
overall you've covered everything...i did my waterpump at about 200k cuz it was leaking, other than that..nothing on the car had to be replaced
Old Aug 25, 2011 | 08:16 AM
NmexMAX's Avatar
dot dot dot ...
@ 80k, it's just like new.
My VQ30 has 240k and 16 years on it the only item I've replaced internally (sort of internally) is the water pump and timing chain pensioner, that's it, still going strong and revving to 7200.
Old Aug 25, 2011 | 08:21 AM
you're VQ has a pension plan?! damn!!!!!!!!
Old Aug 25, 2011 | 09:13 AM
amack's Avatar
hmm, so should I maybe pull the old motor and rebuild it....Im thinking new stronger internals and turbo set up
Old Aug 25, 2011 | 09:15 AM
or you could do a VQ35 swap
Old Aug 25, 2011 | 09:33 AM
NmexMAX's Avatar
dot dot dot ...
Ok this set-up just took the turn that every other engine replacement thread takes.
Old Aug 25, 2011 | 09:43 AM
its not my fault, we both told him the engine is fine
Old Aug 25, 2011 | 09:52 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
smh....youre gonna get banned
lol
Old Aug 26, 2011 | 07:03 AM
amack's Avatar
seriously....are you guys are that quick to ban?! wtf, Im asking legit questions. Im searching for old threads pertaining to what Im needing answers to. I guess I wont voice any opinions.
Old Aug 26, 2011 | 07:09 AM
NmexMAX's Avatar
dot dot dot ...
So, what are your questions aside from what's already been answered?
Old Aug 26, 2011 | 07:44 AM
amack's Avatar
my questions directly pertaining to this thread, although a fairly general one in comparison to the ones that Ill have shortly, Im sure, have been answered. anyhow thanks everyone for the input and chiming in.
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
