Stealing input and amp turn on from bose sub connector ??
Old Sep 7, 2011 | 04:18 AM
maxspeed96CT's Avatar
The original VQ...
My bose sub is intermittent, I'm just going to buy a small amp and a 10" sub.
I searched but it doesn't seem like anyone has done this, can I grab my input and amp turn on from the bose connector . Since ill be unplugging the bose amp/sub anyways.
This would save me the trouble of running wires up into to console . Besides the power wire that is..
Anyone have any diagram links that might help me out . Thanks
Old Sep 7, 2011 | 05:37 AM
djfrestyl's Avatar
Suspension Yoda
It's definitely doable. Let me see if I can find the wire colors for you.
But, if you EVER plan to changing your OEM HU to aftermarket, then I'd advise running the wires from your console. It will save you the efforts later on.
edit:
Found this thread. The link in it is no good but the text has the wire colors.
http://forums.maxima.org/5th-generat...ire-codes.html
Old Sep 7, 2011 | 06:19 AM
The original VQ...
edit:
Thanks man. You make a good point . I've been on the fence about swapping out the headunit . I really don't want to spend the money and the bose sounds decent. Plus I like the clean look. But I swear the bose cd player skips on the slightest bumps, being dropped on 19 doesn't help but it gets annoying..
Old Sep 7, 2011 | 06:52 AM
djfrestyl's Avatar
Suspension Yoda
Change the HU. Your sub may start working again, it will probably cost less than a sub and amp, and the aftermarket deck will make your Bose system sound better overall.
Old Sep 7, 2011 | 09:23 AM
The original VQ...
Well the sub kicks on intermittently on bumps. Lol
Don't think a new head unit will fix that ..
But I don't want to deal with even trying to fix it, which is why I'm thinking of getting a 10 sub , nothing crazy.
Old Sep 7, 2011 | 09:28 AM
djfrestyl's Avatar
Suspension Yoda
Honestly, unless you can replicate the cut-out by physically bumping the sub yourself, a new HU may fix it - I've seen it.
Old Sep 7, 2011 | 09:29 AM
Waxima's Avatar
My Bose sub wasn't broken, but my friend did this for me with an extra 12 he had sitting around. It didn't have an amp so it basically sounded like a slightly upgraded version of the stock setup. I don't know what exactly he did, but from what it looked like he just spliced the wires in to where the Bose sub wires come from. It took him maybe five minutes. You should be fine going this route as long as it's the Bose sub that's the problem and not the head unit or the wiring.
Old Sep 7, 2011 | 09:35 AM
The original VQ...
So your buddie used the bose amp with a different sub ?
I guess I've got to look into the wiring some more and see exactly what my problem is.... I have spare sub all I would have to buy is a amp.. Which for me will come out cheaper then a head unit..
Old Sep 7, 2011 | 09:39 AM
djfrestyl's Avatar
Suspension Yoda
I don't recommend this.
The Bose sub/amp runs at 2ohm. You'll have to find a very low powered sub and wire it down to 2ohm.
Old Sep 7, 2011 | 09:56 AM
The original VQ...
Well a 4ohm sub will work just won't hit at its potential..
Old Sep 7, 2011 | 10:03 AM
The original VQ...
But I'm going to try to stick with my plan of just grabbing the input and amp turn on, the link you posted isn't workin on mobile view gotta wait till I get home to try it.
Old Sep 14, 2011 | 01:28 PM
ravis1019@gmail.com's Avatar
Ive done it to my maxima for the same reason, remember Bose system has the amp in the trunk so if you change to after market HU there's a adapter yo need to purchase inorder to use the Bose amp and not have to rewire your car (plus Bose is 50x4), also I have the oem sub and 1 12 in connected and works fine I will find out thecolors for the plug if you need them, I just got one of those sub adapters that you would connect to your speakers and connected it to there. Also at discount(wherever) they sell this connector set that one end loops around the wire and the other one crimps onto the wire(don't know name) but they are a light blue makes install simple
Old Sep 14, 2011 | 01:42 PM
Really fast don't change you HU, that's not the problem, the oem sub has a connection problem between the sub and amp. Because the amp is screwed on to the sub the vibration damages/ burns out a wire. The sub cutting in and out harassed me for a long time, any questions willing to help
Old Sep 14, 2011 | 06:45 PM
TunerMaxima3000's Avatar
I used the existing triggers and speaker wire to hook up my amp for my sub and my amp for the speakers, I just used the FSM for wiring diagrams and colours, do I really need to post that? We don't have that info? Must be in the Audio section I would think.
Old Sep 14, 2011 | 06:58 PM
T_Behr904's Avatar
I have my Bose sub wiring disconnected going into the sub, and hooked wires up to it to push an 8" Boston G108, 200W RMS. Not sure what the Bose amp puts out, but I get decent sound out of it at mid to 3/4 volume. It definitely could use more wattage though. I also have in a bobo enclosure right now, with the incorrect airspace. It calls for 0.03 cu/ft or 8.5 liters sealed. Bass output is about the same. It's nice not having that annoying rear deck rattling from the Bose sub.
Old Sep 15, 2011 | 02:56 AM
The original VQ...
Ya thats exactly what im trying to do, the audio section doesnt have anything it just says to upgrade the bose headuniut and sub...
But id like to keep my headunit...
This link has been most helpfull
Im still wondering which speaker wires are + or -. And the wires would be low input correct?
I cant seem to find a free FSM anymore for my 01, the g20 or sr20 site I used to use is down ...
Old Sep 15, 2011 | 05:48 AM
I'm not at home but I'll post up for you later today when I get back. I should have a link for the downloadable FSM as well. Everything I did will work for you we have the same year. I even took a few pics while wiring I can post for you.
For now, perouse here: http://forums.maxima.org/5th-generat...e-manauls.html
Old Sep 15, 2011 | 12:37 PM
DennisMik's Avatar
here are 2 places for the FSM. If you have a early production 2000, do not use nicoclub.
http://boredmder.com/FSMs/Nissan
- or -
http://www.nicoclub.com/FSM/maxima
Old Sep 15, 2011 | 04:51 PM
Ok I've been away from home but haven't forgot about this. I may compile it all together and just post it in the audio forum perhaps it will get stickied.
I'll link it here at the very least, but I won't be home until the weekend
Old Sep 16, 2011 | 03:03 AM
The original VQ...
Thanks guys!
9aj9
Apr 5, 2020 12:11 AM
LtLeary
Sep 14, 2015 12:33 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
A32goldylocks
Sep 2, 2015 06:39 AM
