Maxima HID Retrofit Build
Yeah that would be nice if someone can open up the housing,altough I doubt that the reflector style headlights have similar metal bracket like yours. I think it is more he OEM ones.
I'm going to get the reflector style. Defenetly more work but it's a hobby right. I want to explore the carbon fiber wrap also and this style has less curvature compare to your style.
Here are the things that I'm thinking ( more like wish list)
1. Dual beam reflector style EBAY lights.
2. Quad projectors. G37s low beam and RX330 high beam.
3. Frosted E46 shrouds in both low and high
4. Full Carbon Fiber wrapped bezel.
5. Projector lens turn signal retrofit.
6. Dual CCFL for both low and high beam to light up the frosted shrouds.
Wow, that would be a helluva project, but the result extremely impressive!
After looking at pics of my bracket, I noticed the low beam side of the bracket is set back really far to accomodate the projector housing. Now I'm wondering if the reflector style is going to be forward - a lot closer to the lens, since the reflector is not nearly as deep as the projector housing. If that's the case, you can probably cut it and add a bracket to set it back far enough.
Iv'e seen pics of carbon fiber work and it looks really nice. If I open mine up again down the road, I'm going to consider some custom paint work in there - just because my car is all white, and i don't think the carbon fiber would look very good on mine.
Also, check out this thread: http://forums.maxima.org/5th-generat...ngel-eyes.html
Perhaps you can contact umintza and maybe they can provide you the proper brackets, since they seem to sell and mod similar units.
Yeah, I'm not sure if Umintza mods anything in that headlight other than putting HID kit in those Ebay Projector Headlight based on a member that posted the result. I also prefer CCFl from lightwerkz or TRS than the LED based angle eye. Building the bracket isn't a big deal since I have access to CNC Mill/Laser Cutting machine and build the bracket model it in 3D CAD. Once I recieve the headlights I'll take measurement of the adjustment screws mounting points and start laying out the projector location and mounting points. Hopefully this would be a good rovust way for other to do retrofit in the dual housing beam. I can also make the bracket available for other member here for small fee compared to hacking it up with dremel, fitting, cutting again, fitting, etc.
I'm really dragging my feet on this. In all honesty, a quad setup isn't useful IMO. Unless you specifically choose a pair for width and the other pair for distance, but even then I feel like there will be too much foreground which not helping for distance viewing. The quad setup is just a nice to have and a bragging right but I feel that its not worth the investment for the return. I'm pretty content with my E46 BiX setup and Valeo Fog lights, these 2 provide enough width and distance I want. A halogen projector high beam is actually more useful. If I do this it would be cheaper. I calculated the wish list that I want to have, the parts alone cost $700 which is about 15% of my car value and It's still using Ebay headlights instead of OEM.
In the other hand I always wanted to use RX330 or TL. Maybe I should just build another 5th gen retro with TL
02-03 Headlight Retrofit build
There is a possibility that I'm going to do OEM 02-03 retro for a member here. So, I dust off my old OEM reflector parts and see if I can learn few things from the past
LuvLexus,
When you did your Mini D2S, did you use the OEM cap? the shortest projector I have is RX330 and they are still sticking out way more than I want to if I want to use the back cap. What is the clearance between the back cap and the battery side wall?
In the past I wasn't thinking about any clearance issue between the back of the headlight to the battery. If I burry the projector inward it will stick out past the cap and if there is no clearance between the battery side wall and the D2S connector, then it makes is even harder to achieve this.
LuvLexus,
LuvLexus,
LuvLexus,
http://forums.maxima.org/5th-generat...ir-intake.html
hm
Well....the Mini D2S is probably the shortest of all.....that means I can't use the back cap anyways with any projectors that I'm thinking of using...
Yeah, and if the gap between the cap and the battery is not much that makes it even worse. The G37 I'm planning to use is about .5" longer than the Mini, so I'm pretty sure the cap will not be able to fit, so then I gotta come up with an extenstion to cover the back but if the gap is too close you won;t be able to get your hand in there and change the bulb.
^Correct. You don't even have to drill bolt holes, just grab a 3/8" bolt and nut with a few washers. You can still use the stock battery base even.
Took me about 10 minutes to do, minus digging for the hardware (bolt, washer andnut)
Well Tuner, that might just solve half of problem here, that means there is no excuse not to burry the projector deep
.Does this work on all 00-03? I should get my butt outside and check it out my self..
That juntion relay box is super tigth fit also with projector sticking out the back of the high beam area.
Am I missing something here....I'm not seeing I can rotate the battery without major mod.
Ok, here is my battery. I don't think I can rotate it 90 degree and to the left, the tray is fitted to the battery also. I can lose the tray but the left real estate is occupied by air duct that part of the intake looks like.
Does anybody know how to properly aim the bulbs? A friend of mine was pulled over by a cop that thought he was high beaming. My car has them aimed right now but I want to change the bulbs. Will they already be aimed if I just slide the new ones in or do they have to be re-aimed every time I change the bulb?
Actually it's vehicle specific, there's always the general 'rule of thumbs', but the FSM will tell you exactly for your car.
As far as the battery, You're right, with the stock intake it's different. The main reason for relocating the battery is for Intakes, so I never considered the stock intake in the suggestion.
you can still do it, just can't move it as far, and might not be able to use the stock battery tray (might have to buy one or fab one). That relay box has a decent amount of play in the wiring, and it mounts to the stock battery tray anyways, so moving the battery would require it's movement anyways. Just pop the 10mm head bolts off that hold it (2).
First off, because battery sizes differ, i'd measure the length of the battery and just make sure it can turn 90 degrees without hitting the stock airbox.
G37 with STI-R.
Euro does your look like this. That bow in the lower cutoff is quite high. It does help, seeing incoming car perpendicular with the car, but I'm afraid it's too much.
The ebay projectors did that, but on the high side cutoff. Just a big flare. It almost looks like the rotation is off, but more like your are getting some strange reflection angle in there somewhere.
Here's the left side with the right side covered up. I only have a crappy little 3.1 mp camera here, so sorry for the lame shot. You can definitely see the blind spot in there, but it should give you a good idea of the stock flare:
Thanks again.
You got the spacing right Euro, when you back the car up 100', you'll see sharper cut off on the wall..sweet......... I'm settled with the projector choice now. G37 3incher low beam and G37 2.5" low beam. I can't wait for the headlights to arrive......
The hit & miss is half the fun of these projects, lol!
Instead of raising the shield, if you can figure out where the reflection is coming from and paint that section you won't have to compromise the extra lighting.
One of these days I'll get around to fixing thatblind spot. Maybe when you post pics of your quad setup I'll motivate and maybe even try the same!
you already have the bracket in there. All you need to do is take the high beam relfector out and place the projector in.
00-03 Quads
Got my headlights today, looks pretty good so far.
G37 Bi-X coupe on the left, G37 Bi-X sedan on the right
Random picture of current E46 wall shot.....
G37 coupe stock untouched
G37 coupe + clear lens
But nothing beat this so far, my all time favorite.....RX330 + Custom Shield + Clear Lens. I could look at this all day......
Can't wait to crack those newly wrapped headlights open.....
I've always wanted to try quads. It's really not necessary or that quad is better than dual retrofit, but it's defenetly fun project. I'll have it on dedicated switch also, so I can toggle it. Most of the time I'll be running dual only, I don't want wearing sun glasses at night
. I'm pretty happy with my E46 actually so, we'll see. I want to try different form of CCFL/Halo. I want to try using frosted shrouds and use the projector to light up the shroud, kinda like M45 projectors in Infiniti. Heck I'll slap M45 projector in there if it fits.This is M45 projector lit up. it's cool
