Motor Mounts Bad?
Old Sep 9, 2011 | 07:38 PM
colind94's Avatar
Motor Mounts Bad?
Hey, I want to start out by saying that I did search for an answer but I couldn't find exactly the answer I was looking for.
So when my car is turned ON ( key on ignition off) and the hood is up I hear a loud whining sound almost like an electric motor running. But when the engine is turned on I cannot hear it at all. I don't know if it is because it is impossible to hear it over the engine, or I just can't hear right. Also when the key is in the on position and the hood is down, it is very faint or almost non-existent. I know the hood has nothing to do with it, but I'm just trying to describe the noise level of it.
Lastly will simply unplugging my motor mounts hurt it or give me an ses? How many do I have? 2000 gle.
Thanks for all help!
Old Sep 9, 2011 | 07:47 PM
Montego Murph's Avatar
Is it constant or does it go away after a short time?
It could be the fuel pump priming the system.
Old Sep 9, 2011 | 08:06 PM
xumengpeter's Avatar
u can unplug it with no ses light, mine is 03 and has only one electric mount, it is the one close to the radiator. urs should be the same..
Old Sep 9, 2011 | 08:11 PM
MONTE 01&97 SE's Avatar
Yeah unplug it and see if the sound goes away...because if it is that and you keep it connected it could fry your ecu as many have experienced here...then you are in real expensive trouble.......If it is that and you unplug it you will have slightly more vibration at idle.
Old Sep 9, 2011 | 08:22 PM
nsnrider's Avatar
I've never ran into a car where a bad motor mount caused an ecu failure but I guess some people on the board experienced just that. You can easily unplug both (if you have two) electric mounts and see if any noise exists.
good luck.
Old Sep 9, 2011 | 08:59 PM
good luck.
Well trust me on these cars if you let it go long enough with that buzzing sound and don't unplug them it will!
Old Sep 10, 2011 | 12:42 AM
colind94's Avatar
No it's definatley not the fuel pump. This noise does not go away. It seems to be coming from almost down under the throttle body or in that area. Is a motor mount failure an absolute guarantee that you'll fry the Ecu?
Old Sep 10, 2011 | 04:13 AM
buddywh1's Avatar
Isn't the fuel pump back in the gas tank? I'm curious about this 'cause mine makes a buzzing or humming sound too and I disconnected the electronic motor mounts a long time ago. It's not so loud, though... but quite noticeable if the engine's not running but ignition is on.
Old Sep 10, 2011 | 07:26 PM
Lsgun1's Avatar
Sound travels strangely sometimes so I would try unplugging the alternator if it wasn't the mounts.
matts95max
Apr 23, 2025 10:44 AM
wyobbagy
Jan 3, 2023 12:03 PM
The Frye
Sep 2, 2021 11:03 AM
HOKUSMAX
Nov 13, 2017 04:34 AM
